Ok whenever i try and make a layout im having this stupid problem first off all im doin is making One table then inserting another. But for some reason whenever i insert a image in both the top and the bottom it dosent stack right. Theres this gap wheres the lines are from the table. It never used to do this Why is it doing this now. Please any idea on what could be causing this tell me. Thx Here are 2 screen shots of the problem on diffrent layouts.
http://i3.photobucke...ud54367/Gap.jpg
http://i3.photobucke...54367/Ublah.jpg
All help is welcome thx
Dreamweaver Problem
Started by Cloud54367, Aug 01 2005 10:55 PM
2 replies to this topic
Posted 01 August 2005 - 10:55 PM
Posted 01 August 2005 - 11:40 PM
Well... your screenshots are tiny, I can't see the problem, sorry.
Posted 02 August 2005 - 03:14 AM
Well, I don't know about you but I can't see a dam thing on those screen shots! When using tables make sure you define cellpadding="0" and cellspacing="0".
Make youe screen shots bigger!
Edited by softLearner, 02 August 2005 - 03:14 AM.
