help making layout
11 replies to this topic
#1 drunkenmunky101
  • 14 posts
Posted 02 August 2005 - 07:50 PM
Hi. So I have a site and i want to make a layout for it. Do i first make a layout in photoshop and then transfer it to dreamweaver?
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 02 August 2005 - 09:14 PM
You first design it in photoshop, then you learn html, and code it from scratch in dreamweaver.
I say this because if you export it using photoshop, you will run into more problems then it's worth.
#3 drunkenmunky101
  • 14 posts
Posted 03 August 2005 - 11:16 AM
where can i learn html? is there some tutorial i can read?
#4 Silwolffe
  • 707 posts
Posted 03 August 2005 - 11:45 AM
http:/www.w3schools.com
Learn HTML first and then progress onto CSS (Cascading Style Sheets). Both are important for web-design.
#5 softLearner
  • 128 posts
Posted 03 August 2005 - 12:25 PM
Ha! Silwolffe did a samll booboo! he for got the 2nd / (forward slash in http://) The url for w3schools is http://w3schools.com
That is the best place to start learning HTML, and yeah go on to using CSS to learn how to style your pages. There is lots of free tutorials hanging about for HTML.
Heres acouple of more sites:
http://pageresource.com
http://yourhtmlsource.com
Two good sites for learning HTML and CSS.
Edited by softLearner, 03 August 2005 - 12:28 PM.
#6 Silwolffe
  • 707 posts
Posted 03 August 2005 - 01:07 PM
Tis what I deserve for writing too fast. :P
I'm sure he would have figured it out.
#7 adamfran
  • 91 posts
Posted 03 August 2005 - 01:54 PM
and SoftLearner you forgot to put www. :P
Adam
#8 softLearner
  • 128 posts
Posted 04 August 2005 - 05:02 AM
U don't really need the www. in the URL. lol
Edited by softLearner, 04 August 2005 - 05:03 AM.
#9 Silwolffe
  • 707 posts
Posted 04 August 2005 - 10:49 AM
Click it, it doesn't read the URL correctly.
You got pwned. :D (b^.')>
#10 drunkenmunky101
  • 14 posts
Posted 04 August 2005 - 01:16 PM
Quote
ok so if i design it in photoshop first what are the dimensions supposed to be so it can fit well on the browsers of the people's computer screens? *edit* also what is this slicing thing i've heard ppl talk about?
Edited by drunkenmunky101, 04 August 2005 - 01:18 PM.
#11 wimmar
  • 28 posts
  • Interests:Pixel2Life and webdesign :p
Posted 05 August 2005 - 05:18 AM
You slice your template in pieces and then u save for web,
then you have a html file with all images, just edit this one and you have your site :lol:
are u going to use PHP or iframes or frames?
#12 drunkenmunky101
  • 14 posts
Posted 05 August 2005 - 08:07 AM
i have no idea....which one should i use and how do i use it???
