Maya 7 HELP
6 replies to this topic
#1 Deathskin
  • 70 posts
Posted 18 August 2005 - 01:18 PM
when i make a cube, and then use the split polygon tool to make 2 new vertices in the new cube to make 2 squares out of one face of the cube and then go to SPLIT VERTEX then use to extrude face key, it doesnt have a gap between both sides when i split them apart even though i split up the vertices.
im trying to follow the Polygonal Modeling to make a hammer, a tutorial that came with Maya 7 and i followed it exactly, but i cant get the gap to come ( i did once before but i dont know how i did it, i did it exactly like it said to and it worked) but lately it hasnt been working :P
Any help would be appreciated.
#2 Deathskin
  • 70 posts
Posted 18 August 2005 - 03:29 PM
nevermind, it turns out i was doing everything right, but i didnt read it right. I had to drag the manipulator tool arrow inward instead of outward.
thanks anyways
#3 BeaverElfeater
  • 640 posts
Posted 18 August 2005 - 03:45 PM
you got maya 7?????
#4 Deathskin
  • 70 posts
Posted 18 August 2005 - 05:48 PM
yup
#5 _*Speed_*
  • Guests
Posted 18 August 2005 - 07:51 PM
I had a problem similar to yours in Maya 7, but I found the solution.
#6 Deathskin
  • 70 posts
Posted 18 August 2005 - 08:14 PM
Does anyone know how to save as diffrent formats? because when i go to FILE>SAVE SCENE AS you can only save it as a mb, or something similar that only MAYA can open.
Any help, i know its a dumb question :) but its stumping me and i read everything about saving scenes :P
#7 BaRToNiX
  • 8 posts
Posted 16 October 2005 - 08:12 PM
You mean, when you try to move a face, it brings it's neighbor along with it kinda, well to fix that, make an extra span going down blocking it off, I'd suggest you use extrude face as a method of preventing that, it'll just pop the face out. Hopefully that helped you. Good luck.
