need photoshop help
4 replies to this topic
#1 _*Bujashaka_*
  • Guests
Posted 16 September 2004 - 07:23 PM
how can i do rounder corner with gradient tool so that it loks like pipe turns 90degrees, i tryed with lightning effect way, using alpha channel etc. but the result is too smooth.
#2 _*Andy_*
  • Guests
Posted 17 September 2004 - 02:28 PM
Im not sure if you mean like this....
Like that? if not... then please explain a bit more :D
Andy
#3 _*Bujashaka_*
  • Guests
Posted 18 September 2004 - 06:54 AM
exactly like that, but the corner should be rounded... so hows that done
#4 _*Andy_*
  • Guests
Posted 18 September 2004 - 10:32 AM
there are numerous ways.... if your a bit of a noob... you could try using the circular marquee tool. or an easier way would be.... maybe the eraser tool.
Andy
#5 _*Jag_*
  • Guests
Posted 18 September 2004 - 01:24 PM
I'd suggest, if you follow andy's thingy (no, not that thingy), that you press and hold "Ctrl+e" to merge your layers, then holding "ctrl" select that one layer in your layer palette. Select>Inverse Then Select>Smooth and how many pixels you want to round it by.
There. Easy :hi:
