Help with sorting
4 replies to this topic
#1 eivindlt
  • 47 posts
Posted 18 September 2005 - 04:52 AM
Hi!
I've been using a file archive for a while now. I downloaded it (I'm a newbie) from mortz.tjokk.net (a norwegian site). The files are automatically sorted by name. How can I sort the files by the date they are uploaded?
Here is the sort-part (i think :) ) of the code:
      sort($files);
      $length = strlen($dir);
      if ($length >= $MaxLenFilename) {
         $length = $MaxLenFilename-3;
         $displaydir = substr($dir, 0, $length) . "...";
      else $displaydir = $dir;
      if (count($files) != 0) {
         echo "<tr><td colspan=\"5\">&nbsp;</td></tr>\n";
            echo "<tr><td colspan=\"3\"><b>$displaydir</b></td><td><b>St&oslash;rr.:</b></td></tr>\n";
The full code can be seen here
Thanks for helping :huh:
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 18 September 2005 - 07:41 PM
As far as i know, php has no way to figure out the "last modified" time of a file. I know javascript does, and php MAY have the capablity to do so also... but i've never found a way to do so...
#3 eivindlt
  • 47 posts
Posted 19 September 2005 - 02:53 AM
Okey, so I can't sort them... Damn :rolleyes:
#4 fiv3isaliv3
  • 258 posts
Posted 19 September 2005 - 02:23 PM
tie it in with a database and just put the date it was modified in there maybe. just a thought.
#5 rc69
    PHP Master PD
  • 3,827 posts
Posted 19 September 2005 - 03:32 PM
Mild correction in my last statement.
http://php.net/manua...n.filemtime.php
I completely forgot about that set of functions
