i figured out how to do PHP pagination but I want have the links in a drop down menu instead of links, how would i do that...ive tried everything...
pagination help...
Started by juketsu, Sep 28 2005 02:40 PM
6 replies to this topic
Posted 28 September 2005 - 02:40 PM
Posted 28 September 2005 - 05:44 PM
Probably the same way you would do the links... Only difference being, the use of javascript.
Try this:
Try this:
function go_to(object){
window.location = object.options[object.selectedIndex].value;
</script>
<select name="name" onChange="go_to(this);">
<option value="URL">DISPLAY</option>
</select>
Posted 28 September 2005 - 06:50 PM
i meant with php pagination...or does that work w/php...
Posted 28 September 2005 - 07:06 PM
Well, as long as the user has a javascript enabled browser, that will work with the php. Naturally, you'll have to use php to echo out the different options with the proper info in place of what i had in caps. But you need to know 2 things.
1. PHP is server side, no more. It can only affect what HTML the end-user actually sees.
2. I have no idea how to make a select box into a link, other then what i showed above. I'm sure there are other ways, but that's the only one i know.
Posted 28 September 2005 - 07:57 PM
ok...thx ne way for ur help...
#6
Posted 29 September 2005 - 01:05 AM
$links = array (
'Google|http://www.google.com/',
'MSN|http://www.msn.com/',
'Yahoo!|http://www.yahoo.com/',
echo "<select>\n";
for ($i = 0; $i < count($links);) {
$link = $links[$i];
list($title, $link) = split('[|]', $link);
echo " <option onclick=\"window.location='$link'\">$title</option>\n";
$i++;
echo "</select>";
That should work for you, just change the links, but make sure you leave the | in between the title and url's
Edited by HaloprO, 29 September 2005 - 01:12 AM.
#7
Posted 29 September 2005 - 06:00 PM
No offense, but you can do 2 things to make that code better.
1. Use the for loop for in the way it's intended to be used, and add all the attributes to the list:
p.s. These are just tips, i'm not trying to argue with anybody or make anybody mad, just point some stuff out.
$links = array (
echo "<select>\n";
for ($i = 0; $i < count($links); $i++) { // Added $i++
$link = $links[$i];
// Moved $i++
echo "</select>";
Or 2. Instead of relying on the split (or explode) functions, use a foreach loop and change the array set up to something like this$links = array ('Google' => 'http://www.google.com/',
'MSN' => 'http://www.msn.com/',
'Yahoo' => 'http://www.yahoo.com/');
Note also the fact that you added a comma after yahoo that shouldn't be there.p.s. These are just tips, i'm not trying to argue with anybody or make anybody mad, just point some stuff out.
