Help me with fastkeys...
Started by mikkal, Oct 13 2005 11:18 AM
3 replies to this topic
Posted 13 October 2005 - 11:18 AM
Hi, I cant do fastkeys... Like if I want to make filter>render>clouds and wanna do it again I need to hit ctrl+f but nothing happens.. I know I just can hit "Filter>clouds" but not so fun when I want to make a cool effect. It takes to long time
well thanks and hope that you will help me
Posted 13 October 2005 - 02:35 PM
ctrl + f should work...
After using photoshop nearly everyday i know all the hot-keys i'll usually use...
Im dotn quite get what help you want, ' fast-key ' revision and help on remembering them or gettig them to work>?
Posted 14 October 2005 - 12:38 PM
Well if i want to make a new document for excample I cant push ctrl+n nothing happens then... i need to go to file>new...
Posted 14 October 2005 - 12:42 PM
Ill try to reinstall...
