How would I go about setting up a material making alpha channels work with out using an opacity map.
Or even if I have to, I want the models to shadow the alpha channel, but usually it just shadows the plane.
Alpha Channels help
Started by Prozac360, Oct 20 2005 03:49 PM
1 reply to this topic
Posted 20 October 2005 - 03:49 PM
Posted 20 October 2005 - 03:55 PM
save the render as .tga format, take it into photoshop double click the image and turn it into a layer, click the channels palet > click the bottom layer called alpha and 'load channel as selection' go back to the layers palette and click on the layer, select > inverse. hit delete. background is gone.
