I NEED HELP ASAP
4 replies to this topic
#1 syntex
  • 3,126 posts
  • Interests:Poetry, Photography, Music, My Band, Guitar and out of my mind experiences.
Posted 13 November 2005 - 06:47 AM
Ok i need anyone who could help me fix this thing,
I got a virus it keeps insisting i install "spysheriff" does anybody have (or had) the same problem,
Thanks in advance
PS: There is a file called "secure32" in my C Drive that keeps coming back also
AND.. It wont let me change my wallpaper
#2 Ckristian
    Honored X Staff
  • 1,334 posts
  • Interests:Programming...
Posted 13 November 2005 - 06:53 AM
http://labs.paretolo...move=SpySheriff
http://forums.majorg...ead.php?t=65945
#3 syntex
  • 3,126 posts
Posted 13 November 2005 - 07:26 AM
Ok i got spy sheriff out,
Now there is this one file called "secure32.html" thats really starting to bug me cos it never deletes,
Any solutions?
#4 Canen Art
Posted 13 November 2005 - 12:35 PM
Not sure if you tried this or not, but certain things will stay backed up on your system because of your system restore if you have windows xp.
If you do have windows xp or pro, right click on your my computer and click properties and select the tab for System Restore and you will notice a box that says Turn off system restores on all drives. Put a check in that box then go delete that file that wont go away and restart your computer after you delete it.
Then go back and uncheck that system restore box and it should have removed the file for good.
I hope this helps.
Regards,
Jason <3
#5 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 13 November 2005 - 12:50 PM
Google is a brilliant tool when you have viruses and spware amazing what you can find <3
You need to run HijackThis and post your log at http://castlecops.com/ as there could be several variations of this pest.
Download HijackThis
http://www.merijn.or.../hijackthis.zip
Run it and click on Scan.
Let it run to completion.
Do not remove anything in there yet as not all items are bad.
Then when it is finished click on Save log.
A screen will pop up with Save logfile... Click on Save.
Notepad will open up.
This is the full log that is needed to copy and create a new topic in that forum above they will go through your log and give you instructions what to remove and probably tell you if you have other weird stuff.
