Problem with space-[php]
5 replies to this topic
#1 liveman
  • 246 posts
Posted 13 November 2005 - 11:06 PM
Hello,
Ok well I created a script for AIM to log who clicked the button...ok well It works great with 1 exception...whenever there is a space it messes it up, and only puts the letters before the space...so I was thinking of ways to defeat that problem.
The first thing is to use ereg function, but one problem...what would I look for &nsbp; ? or another thing...that calls the space :D ok...if anyone has any other suggestions..please tell me!
#2 tiki
  • 259 posts
Posted 13 November 2005 - 11:49 PM
Try   ?
#3 liveman
  • 246 posts
Posted 14 November 2005 - 06:46 AM
Ok, well what I found out is that its aims problem...in a normal broswer it puts %20 in for spaces, but on aim It cuts words....so when it clicks to send the info it only sends up to the space :D so that means I need to get there screenname in there...anyone know how I can do that?
#4 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 14 November 2005 - 05:26 PM
  is an htmlentity. It's short for non-breaking space. It's translated by the browser, php sees it exactly as-is.
ereg() does have a pattern to automatically match spaces (i believe its [:space:], but i don't use that form of regex, so i don't know).
So why not try replacing the spaces with an underscore (_)? That'd be easiest... unless underscores are a bigger part of it.
#5 kcd
  • 10 posts
Posted 17 November 2005 - 09:39 AM
dosent just normal space bar work.
it dose for me.
Edited by kcd, 17 November 2005 - 09:41 AM.
#6 Sicloan
  • 31 posts
Posted 17 November 2005 - 04:04 PM
just use a replace(); functions
$string = "hello bob!";
$string = str_replace(" ","_",$string);
output = "hello_bob!";
I also suggest taking a look at the ereg_replace(); php function page...
http://us2.php.net/m...reg-replace.php
Edited by Sicloan, 17 November 2005 - 04:04 PM.
