smarty & mojavi help
4 replies to this topic
#1 kknaru
  • 10 posts
Posted 14 November 2005 - 04:56 AM
hy i'm trying to change the design of an site that is made with smarty and mojavi!
i got no ideea about those aplications,soo...i need help :D
what i've heared is that it's even simple to change the design of a site with mojavi or smarty!
so..what are the first steps in working with those aplications(considering that i have no clue about smarty & mojavi), any advice will be apreciated :D
Edited by kknaru, 14 November 2005 - 07:44 AM.
#2 kknaru
  • 10 posts
Posted 14 November 2005 - 08:30 AM
should i modify the .tpl files or what?
#3 Chaos King
    Senior Programmer
  • 676 posts
Posted 14 November 2005 - 02:14 PM
That would be the first thing I would do. Make sure that you backup all your files incase you change your mind. Just change the .tpl files to suit your design that you are trying to intergrate into the script. How hard can it be? :P
#4 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 14 November 2005 - 05:29 PM
Have you tried looking at the smarty website? I'm sure they have all the info you could ever want, and a contact form of some kind that you can ask the creator of the script about.
And working with them is not really any different then working with normal html.
The catch is, you need to make sure all the comments are the same (because i believe that's what they use to change things).
#5 kknaru
  • 10 posts
Posted 17 November 2005 - 09:13 AM
thank you all people :) that was my first day of "reasearch" in smarty :D now i know what i have to do and how simple becomes changing the design using smarty! 10x again
Edited by kknaru, 17 November 2005 - 09:15 AM.
