Hi all,
First, huge thanks to funkysoul for doing these tuts...awsome!
When I try to load the audioplayer3.swf into my main.fla, I get two different problems.
I have tried using an mc (just a box, with the registration point at the top left) on the main timeline, name the instance of the mc "player", and put the following in the keyframe:
player.loadMovie ("audioplayer3.swf");
I get the player to load (both .swf files are in the same dir with the .xml and the .mp3 files), but it's all garbled with asdf showing above the buttons, no working volume, no song boxes, and more.
I have also tried loading it using this on the main timeline instead:
loadMovieNum ("bar.swf", 1);
and it loads (in the middle of the main .swf), but the volume is muted by default.
I would very much like to use the method of importing via target if possible.
Thanks!
help loading funkysoul's MP3 player into another .swf
Started by Damaged1, Dec 02 2005 02:32 PM
2 replies to this topic
