Some help
7 replies to this topic
#1 459Productions
  • 164 posts
Posted 09 December 2005 - 12:40 PM
So Ive been making sites and such for about a year now and Ive come to realize to get my site more professional and more high tech I need to learn some more coding skills. What I have been doing is just painting the site in Photoshop then slicing it and loading the html into DW and then pretty much just go from there using the images. I know this is completely wrong so i was wondering if someone could give me a quick guide or something to get me started on the right track? Thanks Kyle
#2 iPod
  • 63 posts
Posted 09 December 2005 - 02:03 PM
There are many many tutorials linked here on the site you know..
Just use them, but remember don't just copy the information, try to learn something from them.
Good Luck and Have Fun.
#3 SKETCHi
  • 117 posts
Posted 09 December 2005 - 03:46 PM
There are a bunch of tutorials here, but I've found a website with great guides for HTML, CSS and XHTML. Check out http://www.w3schools.com/
#4 Cable
  • 3 posts
Posted 09 December 2005 - 04:00 PM
After working with DreamWeaver and HTML, I would suggest learning CSS and XHTML.
Most people use it nowadays, and the coding is much neater.
It's easy to understand, and makes coding your layouts much easier. As iPoD stated above, this site has perfect resources to get you started.
#5 coolaid
    P2L Jedi Master
  • 1,435 posts
  • Interests:i wonder..
Posted 09 December 2005 - 04:37 PM
w3schools is a reference site, not a tutorial site. thats the way i see it.
anyway, i have a tutorial if you want to start learning xhtml / css.
http://scudworkz.com...s/firstwebpage/
#6 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 09 December 2005 - 04:41 PM
W3Schools is one of the largest web building tutorial Sites on the web, not sure where you get its not its always been like that, its also a reference site and you can also become certified.
Did you not see all of these?
HTML Tutorials
Learn HTML
Learn XHTML
Learn CSS
Learn TCP/IP
XML Tutorials
Learn XML
Learn XSL
Learn XSLT
Learn XSL-FO
Learn XPath
Learn XQuery
Learn XLink
Learn XPointer
Learn DTD
Learn Schema
Learn XML DOM
Learn XForms
Learn SOAP
Learn WSDL
Learn RDF
Learn RSS
Learn WAP
Learn Web Services
Browser Scripting
Learn javascript
Learn HTML DOM
Learn DHTML
Learn VBScript
Learn E4X
Learn WMLScript
Server Scripting
Learn SQL
Learn ASP
Learn ADO
Learn PHP
.NET (dotnet)
.NET Microsoft
.NET ASP
.NET Mobile
Multimedia
Learn Media
Learn SMIL
Learn SVG
Learn Flash
Web Building
Web Building
Web W3C
Web Browsers
Web Quality
Web Semantic
Web Careers
Web Hosting
Web Certification
#7 Stu
  • Publishing Betazoids
  • 1,761 posts
Posted 09 December 2005 - 07:41 PM
i think the next logical step after youve been using imageready generated code, would be to slice your site and then code it using the images, as oppose to using the sloppy generated code.
have a look at fakens slicing guide (for you it would be the coding part)
http://www.slicingguide.com
from there on go to using xhtml css etc.
personally i think you should follow the stepping stones and not jump over them. i know before when i first tried to code my site as oppose to using the generated code from image ready i found it quite hard, so i wouldnt skip it just for the sake of learning how to create a site using css, as at some point in time you might come across a scenario where you might need those skills that you have avoided learning.
its a natural progression, take your time :)
up to you though :)
#8 459Productions
  • 164 posts
Posted 09 December 2005 - 11:49 PM
Thanks for the quick replys everyone I will begin version 3 of my site lol but take my time this time and get the code I want it and learn some css! Thanks again Kyle
