I have a gradient that I want in a different color, how can I do this? (I have a specific color that I want it to be)
Is it possible to match colors for the gradient?
I'm using Photoshop 6
color conversion
Started by Hacker-X, Dec 10 2005 11:41 AM
6 replies to this topic
Posted 10 December 2005 - 11:41 AM
Posted 10 December 2005 - 02:38 PM
why dont you just add the new gradient over the old gradient
Posted 10 December 2005 - 03:27 PM
Thats what I plan on doing but I need the same colors just different hues. I need to convert the colors to different colors.
Posted 10 December 2005 - 03:29 PM
Hit CTRL+U and adjust the sliders.
Posted 10 December 2005 - 05:59 PM
I know I can use CTRL+U to change the colors but I want to know how I can change colors with the layer style gradient, if I CTRL+U now nothing happens because I'm using the layer style gradient.
#6
Posted 10 December 2005 - 08:30 PM
add a color overlay and change the blend mode to hue or color.
#7
Posted 11 December 2005 - 11:00 PM
What coolaid said works, but there's something else you can do to edit the actual gradient layer style.
Just open up the gradient editor in the layer styles window, open up the color select window for whichever section of the gradient you want to change. You can change the value labelled as "H" to change the hue without disturbing the brightness or saturation.
But for an easier way just do what coolaid said.
