Resize problem
Started by arcath, Dec 10 2005 03:39 PM
5 replies to this topic
Posted 10 December 2005 - 03:39 PM
when i was doing a bit of minor editing and accidently saved the PSD of my logo after i had reduced it to 100x100. now i cant get it back 2 500x500 and its quailty isnt the best anymore. any1 know away of rstoring it?? i know i should have made a copy of the PSD well i did but i lost my pen drive and that had it on
adn just my luck my new 1 arrivied in the post bout 10 minutes after i had done it
Posted 10 December 2005 - 04:49 PM
Doesn't PSD's cache the tool history so you can just step backwards?
Posted 11 December 2005 - 03:01 AM
yes but that disappears after you close it, cause i saved it when i was closin photoshop, i acidently pressed yes
Posted 11 December 2005 - 07:13 AM
Did you actually make it 100 * 100 or just zoomed out?
Posted 11 December 2005 - 10:53 PM
He said he closed it. If he had zoomed out, closed it, then opened it again there would be no issue.
I'm afraid you're out of luck as far as I know. I always fear I'll do something like that. You'll just have to remake it.
#6
Posted 15 December 2005 - 02:27 AM
I found a 500x500 PNG of it, which adobe puts the transparretn bg in., so all is not lost! i just dont have the layers
