Problem with Admin script
2 replies to this topic
#1 demonix
  • 26 posts
Posted 09 January 2006 - 02:43 PM
ok here is the script:
session_start();
if($login_username=="") {
Header("Location: login.html");
<div align="center">
if($_POST['submit']){
$index = $_POST['index'];
$guild = $_POST['guild'];
$aff = $_POST['aff'];
$connect = include("connect.php");
$sql = 'UPDATE `index` SET `message` = `$index` LIMIT 1;';
if ($connect && mysql_query($sql)) {
   echo "Index Message Updated Successfully.<br />";
} else {
   echo "Error: pages not updated.<br />";
$sql = 'UPDATE `guild` SET `message` = `$guild` LIMIT 1;';
   echo "Guild Message Updated Successfully.<br />";
} else {
if ($aff == "") {echo "There are no affiliates to add!";}
else {
$sql = "INSERT INTO aff VALUES ('$aff')";
   echo "Affiliates Updated Successfully.<br />";
} else {
?></div>
<title>Shadow Effect - Admin</title>
<form method="post">
  <table width="200" border="1" align="center">
	<tr>
	  <td><div align="center">Index Events </div></td>
	  <td><textarea id="index" name="index" rows="5" cols="30"><?
	  include ("connect.php");
	  $result = mysql_query("select * from `index`");
		while($r=mysql_fetch_array($result)) {
$welcome = $r["message"];
echo "$welcome";
	 } ?></textarea></td>
	  <td><div align="center">Guild Events </div></td>
	  <td><textarea id="guild" name="guild" rows="5" cols="30"><? 	  include ("connect.php");
	  $result = mysql_query("select * from `guild`");
$message = $r["message"];
echo "$message";
		<p>Add New Affiliate(This will only change if you enter something.) </p>
		</div></td>
	  <td><input type="text" name="Add_new" /></td>
	</tr>
  </table>
  <p align="center">
	<input name="submit" type="submit" value="Submit" onClick='update.php'"/>
	<input name="reset" type="reset" value="Reset" />
	</p>
  <p align="center">&nbsp; </p>
</form>
for some reason, it won't update the rows... any help?
#2 MillerTime
  • 69 posts
Posted 09 January 2006 - 07:46 PM
$sql = "UPDATE `index` SET `message` = '$index' LIMIT 1";
$sql = "UPDATE `guild` SET `message` = '$guild' LIMIT 1";
try those as your update sql..
#3 demonix
  • 26 posts
Posted 09 January 2006 - 08:19 PM
yay it worked thank you!
