Car headlight lighting help plz! (3ds max)
4 replies to this topic
#1 Jman11
  • 7 posts
Posted 09 January 2006 - 05:14 PM
Plz tell me how to make a realistic lighting effect for a car headlight, i have checked everywhere and have no luck.
Thx
#2 Stu
  • Publishing Betazoids
  • 1,761 posts
Posted 09 January 2006 - 07:20 PM
program? renderer? pls be a bit more specific
#3 Jman11
  • 7 posts
Posted 10 January 2006 - 09:39 PM
i am using 3ds max 7, and i am using brazil rio renderer (if u can plz explain how to do it in scanline renderer too)
#4 Scythar
    Honored X Staff
  • 1,888 posts
Posted 11 January 2006 - 02:55 PM
here goes nothing, just try this: (scanline renderer):
1. create > lights > standard lights > target spotlight
2. position it like the beam comes out the headlight of the car
3. open modify panel > spotlight parameters hotspot value to 20 and falloff to 25
4. in atmospheres and effects rollout: click add button, select volume light from the dialogue box that appears and click ok
5. select the volume light effect in the list within the atmosphrere and effect rollout and click the setup button
6. set the density to 100 (i would experiment with this one if i were you)
7. then just shift click to make a copy for the other headlights.
(tutorial from 3ds max bible)
#5 Jman11
  • 7 posts
Posted 11 January 2006 - 08:06 PM
Thx alot! plz some1 get me a brazil rio tutorial.
thanks ^_^
