loop problems
3 replies to this topic
#1 FlashGameboy
  • 139 posts
  • Interests:Mostly flash but im trying to work on Maya and some<br />signiture design
Posted 10 January 2006 - 05:08 PM
im using a tutorial that says the following code plays at least once
a = 0
for(i=min; i<100; i++){
a++;
trace("this loop is working")
it doesn't even trace once so i'm assuming it didn't play at all
also this code doesn't play once either:
a = 0
i = min
while(i<100){
a++;
i++;
same problem here no trace
#2 ronson
    Banned For Being Purple
  • 480 posts
  • Interests:Rugby, Programming, Building Computers, Networking, Web Design and...........BINGE DRINKING!!!!!!.
Posted 10 January 2006 - 05:18 PM
Well i'm not actionscripter, i hate the stuff but i'm thinking that your problem with the first line...
Just looked up the FOR loop in actionscript and the only error i can actually see with your code is you don't have a space between
the ){ at the end of the first line.
Another thing is, have you declared "min" that you use in the loop? I think for even actionscript you must declare it.
For example
Dim i as integer
For i = 1 to 10
<code here>
Next I
Is it bring up any errors?
Hope it helps.
James
Edited by ronson, 10 January 2006 - 05:32 PM.
#3 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 10 January 2006 - 06:52 PM
ok first of all.. why you telling i=min? you didn't define min yet...
anyways, FOR loops are being written like this:
a = 0;
for(i=0; i<100; i++){
	a++;
	trace("this loop is working"+i); //added the variable I to check the nice numbers :p
your second actionscript has the same problem.. you didn't defined "min" anywhere.. from where should flash know what min means? :ph34r:
so again the right code would be:
a = 0;
i = 50;
while(i<100){
	a++;
	i++;
	trace("this loop is working");
Everything cool now? :D
Have fun :mellow:
Funkysoul
#4 FlashGameboy
  • 139 posts
Posted 11 January 2006 - 06:57 PM
Yeah, I think the problem is that the book im using isn't very accurate it says
that it would work and play just once. Thanks for solving my problem.
^_^ ^_^ ^_^ ^_^
