mod_rewrite help
6 replies to this topic
#1 FFX
  • 105 posts
Posted 28 February 2006 - 07:34 PM
I am currently trying to turn
clicks.php?type=aff&aid=1
into
out/1/ (1 being the id of the affiliate)
In htaccess i put this code
RewriteRule ^out/[#aff_id]/?$ clicks.php?type=aff&aid=[#aff_id] [QSA,L]
and in the php link.
out/[aff_id]/
when i click the link it goes to /out/1/ (etc)
but the site it is supposed to go to doesn't work :(
Can anybody please help me ?
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 28 February 2006 - 09:28 PM
You need to use regex in the .htaccess, theres a great tutorial in "the answers to all your questions" sticky in this section on how to use it.
But, in short, you need to use:
RewriteRule ^out/[0-9]+/?$ clicks.php?type=aff&aid=$1
#3 Wybe
  • 399 posts
  • Interests:Graphic design, digital and traditional, street style, graffiti, guerilla drawing, typography, coding, sex
Posted 06 March 2006 - 11:43 AM
but the site it is supposed to go to doesn't work ^_^
Sounds like the mod_rewrite works fine only you forgot to make a proper clicks.php, which is ultimately responsible for redirecting the user to an affiliate (I think that's it, isnt it?)
#4 FFX
  • 105 posts
Posted 07 March 2006 - 02:50 PM
its working fine now thanks
#5 FFX
  • 105 posts
Posted 10 March 2006 - 08:59 AM
sorry for double post but i have now got another problem.
I looked on that site with mod_rewrite but couldnt find what i wanted.
i have this
RewriteRule ^[a-zA-Z0-9]/?$ index.php?id=author&author=[#t-wname]
so the [a-zA-Z0-9] mean that it can be any letters and any numbers, but when i try something like /Tutorial Pulse/ with a space i get page cannot be found so im guessing that i need to put something in the [a-zA-Z0-9] for a space, ive looked everywhere but I can't find it.
Can anybody help ?so the [a-zA-Z0-9] mean that it can be any letters and any numbers, but when i try something like /Tutorial Pulse/ with a space i get page cannot be found so im guessing that i need to put something in the
#6 Av-
    I Feel Left Out
  • 1,971 posts
Posted 10 March 2006 - 09:08 AM
I dont think you can use spaces, i suggest you use dashes instead
#7 FFX
  • 105 posts
Posted 10 March 2006 - 12:27 PM
Ok i tried using a _ so it was like Tutorial_Pulse and that worked.
thanks anyway
