I've built my photography biz homepage almost completely in Photoshop - www.bpgallery.com. And I want to use this background color and buttons in the gallery pages - ie. www.bpgallery.com/images/portraits.htm, (page created using Fireworks). Unfortunately when I create my new page in Photoshop, I am unable to move the file into Fireworks and keep the onMouseOver events. And I've only been able to get Fireworks to allow me to use the Swap images.
here is an example of the end result I am looking for - http://www.boydander...m/families.html.
any suggestions?
does this sound a little far fetched or do you think it would work?
what if i created 2 seperate html files - one from Fireworks of the Swap images and one from Photoshop of the Rollover buttons. then i can export the Fireworks PNG file to a html file, and then copy/paste the code from the Photoshop html file.
Need help with Rollover buttons Swap images and Slices
Started by rx8photo, Mar 02 2006 10:55 AM
1 reply to this topic
Posted 02 March 2006 - 10:55 AM
Posted 02 March 2006 - 06:24 PM
My suggestion would be to not use fireworks and all, and only design in photoshop, not slice. Then, learn html and code the template yourself.
Note: You'll also have to learn CSS or JavaScript to get the rollover effect.
