Hey all,
I need the login fields as an image and still be able to put text on it. As you can see on my site [url="http://www.celoxdesigns.com"]celoxdesigns[/url] I really need it cause the default login looks really bad on that metal. This is te code i got now, I'll name the things i tried after the working code.
[quote]<input name="ws_user" type="text" class="form_username" onFocus="this.className='form_on'" onBlur="this.className='form_off'" size="16"><br />
<input name="pwd" type="password" class="form_password" onFocus="this.className='form_on'" onBlur="this.className='form_off'" size="16">
<input type="submit" name="Submit" value="login">[/quote]
Things i tried:
[quote]<input name="ws_user" type="image" src="name.gif" class="form_username" onFocus="this.className='form_on'" onBlur="this.className='form_off'" size="16"><br />
<input name="pwd" type="image" src="password.gif" class="form_password" onFocus="this.className='form_on'" onBlur="this.className='form_off'" size="16">
[u]I also tried[/u]:
- to remove the onfocus and onblur tag but didn't work.
- type="text" src="name.gif/password.gif"
If anyone could help me out that would be great, oh and btw i googled it and didn't find it, only found the way on how to do the submit button as an image.
Thanks in advance,
Celox
<input> help
Started by Celox, Mar 02 2006 03:33 PM
4 replies to this topic
Posted 02 March 2006 - 03:33 PM
Posted 02 March 2006 - 04:53 PM
Add this inside the input tag:
style="background: url(image.gif) top left no-repeat;border:1px #000;"Replace "image.gif" with an image to be placed as the field's background. You can make border 0px if you want.
Posted 03 March 2006 - 01:01 AM
Thanks alot greg, that works great!
Celox
Celox
Posted 03 March 2006 - 01:59 AM
No problem, glad I was helpful.
By the way, you can also add margin-top: 4px; inside style="" to add some spacing between the form vields. Also, I'm not 100% sure on this, but I think you can add this to the input tag so that there is initial text in the form field to let the users know what it's for:
value="Username"
value="Password"
Posted 03 March 2006 - 02:52 AM
Yeah that works, i had it also in the old code at the submit button.
Thanks again for ur fast replies.
Celox
Celox
