<?php $sql = mysql_query("SELECT * FROM files WHERE 'game id'='$game id'");
$rows = mysql_num_rows($sql);
if(isset($rows))
echo "<table width='600' border='0'><tr><td width='150'>";
echo "<a href='/games.php?<?php echo $row_GameFiles['game id']; ?>=<?php echo $row_GameFiles['game id']; ?>&<?php echo $_GET['fileid']; ?>=<?php echo $row_GameFiles['id']; ?'>";
echo "<?php echo $row_GameFiles['title']; ?></a></td>
<td width='390'> </td>
<td width='46'><a href='/games.php?<?php echo $_GET['fileid']; ?>=<?php echo $row_GameFiles['id']; ?>'>Download</a></td>";
echo "
</tr>
</table>";
I know this doesn't work but WHY! :-/ help me please!
PHP Echo Tables Help.
Posted 13 March 2006 - 10:35 PM
Posted 13 March 2006 - 11:35 PM
$row_GameFiles = mysql_fetch_array($sql);
echo "
</tr>
</table>";
oh, and im not sure about the sql, but for a fact '$game id' is not a variable. no spaces allowed.
Edited by coolaid, 13 March 2006 - 11:36 PM.
Posted 13 March 2006 - 11:48 PM
$sql = mysql_query("SELECT * FROM files WHERE game id'='$game_id'") or die(mysql_error());
if(isset($rows))
echo "<a href='/games.php".$row_GameFiles['game id']."=".$row_GameFiles['game id']."&".$_GET['fileid']."=".$row_GameFiles['id'];
// etc...
Your mysql_query was wrong, and it probably prevented anything from being echoed. You were also re-opening/closing the php tag from with-in php (more info about echoing properly: http://php.net/manua...ction.echo.php).Also, where did $row_GameFiles come from?
Edit: Coolaid, you did it again... But i will admit, i forgot to mention the $game id thing.
Edited by rc69, 13 March 2006 - 11:49 PM.
Posted 14 March 2006 - 01:31 AM
CREATE TABLE `files` ( `game id` int(11) NOT NULL, `title` char(255) NOT NULL, `description` char(255) NOT NULL, `author` char(255) NOT NULL, `timestamp` char(255) NOT NULL, `rateing` char(255) NOT NULL, `file dir` char(255) NOT NULL, `status` char(255) NOT NULL, `type` char(255) NOT NULL, `id` mediumint(9) NOT NULL auto_increment, PRIMARY KEY (`id`) ) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=2008;
and
CREATE TABLE `games` ( `name` char(255) NOT NULL, `id` mediumint(9) NOT NULL auto_increment, `files` char(255) NOT NULL, PRIMARY KEY (`id`) ) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=8;
Im trying to check have it sowhen someone clicks on the game name (NAME COLUM from games) that it will match the game's ID with all the files that has been submited and show all the ones w/ the same game id.
Im pretty new at this but im learning fast
Edited by styles, 14 March 2006 - 01:32 AM.
Posted 14 March 2006 - 01:51 AM
but first, its better to leave all variables without spaces (so to replace the column 'game id' with 'gid' or 'game_id').
*******file listing for game*******
$result = mysql_query("select * from files where gid = '". $_GET['id'] ."'");
while($r = mysql_fetch_array($result)){
echo $r['title'] ."<br />\n";
and in the file where it lists the games, have it something like this:
*********games listing******
$result = mysql_query("select * from games");
while($r = mysql_fetch_array($result){
echo "<a href=\"file_listing.php?id=". $r['id'] ."\">". $r['name'] ."</a><br />\n";
that should clear things up?
#6
Posted 14 March 2006 - 03:52 AM
doesn.t like me.. thats if i only have the one script. if i have both it totabbly fucks up. by the one script i mean the top one.
Heres like what im trying to do. Look at the page with only one php script in there that generates the Games from a table. That was simple drag and drop shit. http://www.cheatersdb.com/games.php thats the page. Now i want it so you can click on the games and it will generate from the gameid all the files for that game. how would I do that? I want it all on the games.php page no outside pages.
Thanks So Much!
Edited by styles, 14 March 2006 - 03:55 AM.
#7
Posted 14 March 2006 - 06:03 PM
BUT i changed the column 'game id' to 'gid'..... thats why you get a fetch error.
you just have to switch a few things around. IF you realy dont want to change your column 'game id' to 'gid' then use this code in the file that displays all the files.
$result = mysql_query("select * from files where `game id` = '". $_GET['id'] ."'");
#8
Posted 14 March 2006 - 07:05 PM
doesn't like the ){
part. Im getting Parse error: syntax error, unexpected '{' in /home/.beowulf/hyp3r/cheatersdb.com/games.php on line 162
I did change it and take the space out of games id.
#9
Posted 14 March 2006 - 09:23 PM
Edited by coolaid, 14 March 2006 - 09:23 PM.
#10
Posted 14 March 2006 - 11:49 PM
echo "<a href=\"games.php?id=". $r['id'] ."\">". $r['name'] ."</a><br />\n";
<hr>
//echo $r['title'] ."<br />\n";
echo "<a href=\"games.php?fid=". $r['id'] ."\">". $r['title'] ."</a><br />\n";
$filename = $filedir;
$filename = realpath($filename);
$file_extension = strtolower(substr(strrchr($filename,"."),1));
switch ($file_extension) {
case "pdf": $ctype="application/pdf"; break;
case "exe": $ctype="application/octet-stream"; break;
case "zip": $ctype="application/zip"; break;
case "rar": $ctype="application/x-rar-compressed"; break;
case "doc": $ctype="application/msword"; break;
case "xls": $ctype="application/vnd.ms-excel"; break;
case "ppt": $ctype="application/vnd.ms-powerpoint"; break;
case "gif": $ctype="image/gif"; break;
case "png": $ctype="image/png"; break;
case "jpe": case "jpeg":
case "jpg": $ctype="image/jpg"; break;
default: $ctype="application/force-download";
if (!file_exists($filename)) {
die("NO FILE HERE");
header("Pragma: public");
header("Expires: 0");
header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
header("Cache-Control: private",false);
header("Content-Type: $ctype");
header("Content-Disposition: attachment; filename=\"".basename($filename)."\";");
header("Content-Transfer-Encoding: binary");
header("Content-Length: ".@filesize($filename));
set_time_limit(0);
@readfile("$filename") or die("File not found.");
whats wrong? its not working right. I want it to grab the filename from the mysql table. on url click download it. But its not working also when you just click on the game name it gives you a File not found.Thanks
Edited by styles, 15 March 2006 - 09:49 PM.
#11
Posted 15 March 2006 - 09:58 PM
then you have a file that displays all files for that game.
now you want what? and post the relavent sql tables too, that would help
#12
Posted 15 March 2006 - 10:07 PM
?>[This shows the games. You click on a game then
<hr>
echo "<a href=\"games.php?fid=". $r['id'] ."\">". $r['title'] ."</a><br />\n"; This shows the file with the FILE ID (This is the same tables as i posted before files and games.Now i wan't it so that when you click on the name of the file inside the game it starts your download thats what this is suposted to do but doesn't work.
set_time_limit(0);
#13
Posted 15 March 2006 - 10:38 PM
e.g.
echo "<a href=\" $thecolumn['withthefileurl'] ."\">". $r['title'] ."</a><br />\n";
just change the column id with the real thing
#14
Posted 15 March 2006 - 11:23 PM
#15
Posted 16 March 2006 - 11:43 PM
Quote
ok, i dont understand what you're tryin to do. from what i read it sounds like you just want a file that can start a download... if thats the case, use a direct link that echoes out the file url in the file-listing page.
#16
Posted 17 March 2006 - 07:46 PM
#17
Posted 17 March 2006 - 09:22 PM
so in a new page (actually games.php). you need to use this code to display the files info.
if(isset($_GET['fid'])){
$result = mysql_query("select * from files where fid = '". $_GET['fid'] ."'");
$r = mysql_fetch_array($result);
echo $r['author'] ."<br />\n";
echo $r['description'] ."<br />\n";
echo "<a href=\"". $r['file dir'] ."\" target=\"_blank\">Download the file</a>";
that should work....
#18
Posted 19 March 2006 - 09:08 PM
Edited by styles, 19 March 2006 - 09:09 PM.
#19
Posted 20 March 2006 - 11:36 AM
Try doing the following:
Echo "<a href='games.php?myVariable=$row_GameFiles['game id']'>Blahblah</a>
Don't open PHP inside PHP
Dotbart
if(isset($rows))
echo "
</tr>
</table>";
I know this doesn't work but WHY! :-/ help me please!#20
Posted 20 March 2006 - 08:25 PM
$resulta = mysql_query("select * from games");
while($ra = mysql_fetch_array($resulta)){
echo "<a href=\"games.php?id=". $ra['id'] ."\">". $ra['name'] ."</a><br />\n";
if(isset($_GET['id'])){
echo "<a href=\"". $r['filedir'] ."\" target=\"_blank\">Download the file</a>";
} else {
echo "Please Select A Game.";
The problem is i don't want the users to know where the file is living so that it saids file=IDOFFILE and while it saids that it downloads it.
