Hi, i've downloaded a template from a site that i'd like to work with in flash. I'd like to change text, images, etc. It's from a template site and they say it's ok to download it and play with it in flash. I can't even figure out how to get started with it.
I know very little about flash, but i'd like to figure these things out and start learning. I'd eventually like to make my sons baseball team a website using flash. There are baseball templates i could just buy, but even if i would do that, i'd still need to change text,images,etc.
I got the template here http://www.entheosweb.com/photoshop_templa...le_template.asp
I downloaded the top middle template. The dark one.
If anyone could give me advice on how to get started changing images, etc. I'd appreciate it.
If it's going to be difficult, then i won't even consider buying a template.
Thanks.
need template help please....
Started by menionleah, Apr 14 2006 07:43 PM
1 reply to this topic
Posted 14 April 2006 - 07:43 PM
Posted 14 April 2006 - 08:19 PM
They are free sample templates from http://www.templatem...e-templates.php I believe they are evaluation templates only. They also have their own support http://www.templatem...com/support.php so I suggest you go there as Pixel2life is in no way associated with Template Monster nor support of their products or template modifications.
If you want to learn Flash we have many tutorials here: http://www.pixel2lif...edia_Flash/All/
