Transparent PNGs not Transparent in IE
6 replies to this topic
#1 Milque
  • 24 posts
Posted 17 April 2006 - 10:48 AM
Hello there!
I have a problem. I made some small pixelly graphics that's meant to be transparent on the web, and saved as PNG. It looks perfect in Firefox, but in IE, the graphics are not transparent. Can anybody tell me what file type should I save my graphics in so that it's transparent in both IE and Firefox?
Thanks in advance!!
#2 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 17 April 2006 - 10:57 AM
You can use transparent pngs files in IE but you need to add a javascript to make them transparent, this won't be problem soon as I believe transparent png files work ok in IE7
Full guide and tutorial:
http://homepage.ntlworld.com/bobosola/
#3 coolaid
    P2L Jedi Master
  • 1,435 posts
  • Interests:i wonder..
Posted 17 April 2006 - 12:25 PM
Quote
.gif
*** EDIT ***
i'll be more informative due to popular demand :D
gif files only have two transparency options, on or off, so when working on the psd, you can't have 'semi-transparent' areas. but as of now, its the only (transparent) file type that works in all browsers.
Edited by coolaid, 17 April 2006 - 12:48 PM.
#4 Milque
  • 24 posts
Posted 17 April 2006 - 01:04 PM
So I just save all PNG images in GIF? But as you said there would be no 'semi-transparent', that would be a problem.
So maybe I'ma go with the Javascript.
Thanks all!
#5 Indigo
    Official Alien
  • 617 posts
  • Interests:Computing in general, especially design and programming of all kinds.
Posted 04 May 2006 - 01:54 PM
Just wondering: What's meant by "Semi-transparent"?
#6 coolaid
    P2L Jedi Master
  • 1,435 posts
Posted 04 May 2006 - 03:03 PM
semi-transparent means not 100% and not 0% visible. its inbetween.
e.g create a new layer and fill it in with a color, get the eraser tool, set it at 30% and erase one piece of the layer, it'll have semi-transparency
#7 Scythar
    Honored X Staff
  • 1,888 posts
Posted 05 May 2006 - 02:12 AM
Typical example is a shadow: it darkens the area, but doesnt really cover it with 1 color (black in most cases)
without semi-transparant you can have a smooth shadow.
