Help please my ps is all caps like this HEY YO it want go lowercase im ps 7 how do i turn get it were i can lowercase.
HELP!
Started by Zerabyte, Apr 18 2006 04:36 PM
3 replies to this topic
Posted 18 April 2006 - 04:36 PM
Posted 18 April 2006 - 05:15 PM
ok first of all you should load your document then select the TYPE tool
at the top of the screen locate this button
this window will appear
make sure its deselected.
hope that helped
hope that helped
Posted 18 April 2006 - 05:18 PM
Open up the Character and Paragraph palette. To do this, select the text tool and at the top of the screen where you can choose fonts, size, etc., click the small window button. A palatte should open up, and under the Character tab, at the bottom, there are text type options like T, T, T, etc. Make sure the TT is not selected.
Should work.
-BBHD
EDIT: Oh well, guess you got to it first. =)
Should work.
-BBHD
Edited by BaseballHeadDan, 18 April 2006 - 05:18 PM.
Posted 18 April 2006 - 05:26 PM
you explained it better
