Help positioning a layer central on top of another layer
6 replies to this topic
#1 donkeymusic
  • 495 posts
Posted 29 April 2006 - 04:41 AM
I am trying to central a layer with a image ontop of another layer but cant seem to get it central, horizontal or vertical,
can anyone help me please?
thanks
#2 Scythar
    Honored X Staff
  • 1,888 posts
Posted 29 April 2006 - 02:22 PM
If you ctrl+alt+shft+click with move tool (actually i am saying this cos i always forget : its either ctrl either alt, but just click both lol) and drag a layer from 1 file to another (select all and then drag from window to window), the layer will automaticly be centered on top of the active layer in the other file.
#3 coolaid
    P2L Jedi Master
  • 1,435 posts
  • Interests:i wonder..
Posted 29 April 2006 - 06:23 PM
you you can ctrl + click on the main image in the layers palette (the one that will have the centered image inside of it). so that brings up it's selection.
then regular click on the layer you want to make cetnered, and then click layer - align - vertical.
then layer- align- horizontal.
:friends:
#4 donkeymusic
  • 495 posts
Posted 30 April 2006 - 12:07 PM
are they te same controls for a mac? as i still cant get it to work
#5 coolaid
    P2L Jedi Master
  • 1,435 posts
Posted 30 April 2006 - 12:57 PM
of course not :) macs dont have an alt key, i just assume you knew the alternative (apple key?)
#6 donkeymusic
  • 495 posts
Posted 01 May 2006 - 08:44 AM
the mac does have ant alt key so thats where i was getting mixed up, cheers
cant get the align option to work so have resorted to holding ctrl down when i drag the image across
however when i drag an image onto the new layer with colour in, it gets changed to a grayscale any ideas?
Edited by donkeymusic, 01 May 2006 - 08:52 AM.
#7 the_ryan
  • 7 posts
Posted 10 May 2006 - 12:08 PM
Hello,
I hope this helps you. Matt Kloskowski over at planet photoshop has made a tutorial on this.
Matts dead center tutorial.
Thanks Ryan.
