I work as a graphic artist and a printer operator. sometimes, i have to catch the color from the hardcopy from our clients, my question is, which is more reliable to use, is it curve, selective color or levels? thanks in advance!
need pro advice
Started by AnmlstcBhvr, Dec 11 2004 05:05 AM
3 replies to this topic
Posted 11 December 2004 - 05:05 AM
hi guys! i'm just wondering if you guys can help me about my small problem.
Posted 11 December 2004 - 06:04 AM
I don’t quite understand... Are you going to CMYK a picture or what are you going to do?
Posted 11 December 2004 - 08:06 AM
we use cmyk process in large format printing. i was just wondering what is the easiest way to color-correct for example, the skin tone.
Posted 11 December 2004 - 05:29 PM
Curve then levels if needed. Sometimes it's hard to digitize a print, because your method of input (scanner, camera) may read some tones differently than say another model scanner or camera. Sometimes you may only need to adjust the red hues or green hues, in which case you would work with curves so no to affect other ranges of color, at least that's what I've found in my experience
