Help with XAMPP
2 replies to this topic
#1 Hacker-X
  • 174 posts
Posted 05 May 2006 - 09:22 PM
XAMPP is an easy to install Apache distribution containing MySQL, PHP and Perl. I also have PHP Designer 2006 which should work with XAMPP. Packaged with XAMPP is PHPMyAdmin, which I've used many times before, however when I setup a database and a table in XAMPP (in PHPMyAdmin) I try using PHP code to interact with the database in which doesn't work. Here are the settings from PHP Designer 2006:
Server path: http://localhost
Local server path: C:\Program Files\xampp\htdocs\
Port: 80
Can anyone help me?
#2 l3lueMage
    Wanna Be Moderator
  • Publishing Betazoids
  • 4,596 posts
Posted 05 May 2006 - 11:49 PM
Hmm, I would read the XAMPP Readme, But Try puting a localhost folder in your C:\
Otherwise I dont think it will work
#3 makavelimx
  • 69 posts
  • Interests:Events Manager of MD5Encryption.com
Posted 06 May 2006 - 11:06 PM
I would recommend using Uniform Server more, it is a much smaller package and does not require installation, U just run 1 file and everything works.
