You're right! ../ actually works fine if I want to go from the file under the drop down menu to another file
Like:
/files/index.html
to
/other/anotherfile.html
But if I am at the file /other/anotherfile.html and I want to go back to a file in "files" (with files you mean the main root folder right?) I get a blank page.
Maybe the problem is that I use the same template for the files in the main root folder and the files in the "other" folder?
Code for the drop down box. Uh, I've got two actually
This is the code in my index.htm (and in all my other file's)
<script language="JavaScript" type="text/JavaScript">function mmLoadMenus() {
if (window.mm_menu_0803103519_0) return;
window.mm_menu_0803103519_0 = new Menu("root",158,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803103519_0.addMenuItem("De Club","location='de_club.htm'");
mm_menu_0803103519_0.addMenuItem("Bestuur","location='het_bestuur.htm'");
mm_menu_0803103519_0.addMenuItem("Colofon","location='colofon.htm'");
mm_menu_0803103519_0.addMenuItem("Huiskeuring","location='huiskeuring.htm'");
mm_menu_0803103519_0.addMenuItem("Nieuws");
mm_menu_0803103519_0.addMenuItem("Algemene vergadering");
mm_menu_0803103519_0.hideOnMouseOut=true;
mm_menu_0803103519_0.bgColor='#FFFFFF';
mm_menu_0803103519_0.menuBorder=1;
mm_menu_0803103519_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803103519_0.menuBorderBgColor='#000000';
window.mm_menu_0803161845_0 = new Menu("root",114,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803161845_0.addMenuItem("Het verhaal");
mm_menu_0803161845_0.addMenuItem("De deelnemers");
mm_menu_0803161845_0.addMenuItem("Activiteiten");
mm_menu_0803161845_0.addMenuItem("Keuringen");
mm_menu_0803161845_0.hideOnMouseOut=true;
mm_menu_0803161845_0.bgColor='#FFFFFF';
mm_menu_0803161845_0.menuBorder=1;
mm_menu_0803161845_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803161845_0.menuBorderBgColor='#000000';
window.mm_menu_0803165217_0 = new Menu("root",95,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803165217_0.addMenuItem("Het verhaal");
mm_menu_0803165217_0.addMenuItem("Bestuur");
mm_menu_0803165217_0.addMenuItem("Deelnemers","location='rayon_deelnemers.htm'");
mm_menu_0803165217_0.addMenuItem("Agenda","location='rayon_agenda.htm'");
mm_menu_0803165217_0.addMenuItem("Keuringen","location='rayon_keuringen.htm'");
mm_menu_0803165217_0.hideOnMouseOut=true;
mm_menu_0803165217_0.bgColor='#FFFFFF';
mm_menu_0803165217_0.menuBorder=1;
mm_menu_0803165217_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803165217_0.menuBorderBgColor='#000000';
window.mm_menu_0803165617_0 = new Menu("root",109,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803165617_0.addMenuItem("Agenda 2006","location='ciliata_agenda.htm'");
mm_menu_0803165617_0.addMenuItem("Contactavond","location='contactavond.htm'");
mm_menu_0803165617_0.hideOnMouseOut=true;
mm_menu_0803165617_0.bgColor='#FFFFFF';
mm_menu_0803165617_0.menuBorder=1;
mm_menu_0803165617_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803165617_0.menuBorderBgColor='#000000';
window.mm_menu_0803170053_0 = new Menu("root",84,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803170053_0.addMenuItem("Algemeen");
mm_menu_0803170053_0.addMenuItem("Vissen");
mm_menu_0803170053_0.addMenuItem("Planten");
mm_menu_0803170053_0.hideOnMouseOut=true;
mm_menu_0803170053_0.bgColor='#FFFFFF';
mm_menu_0803170053_0.menuBorder=1;
mm_menu_0803170053_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803170053_0.menuBorderBgColor='#000000';
window.mm_menu_0803170631_0 = new Menu("root",106,18,"Arial, Helvetica, sans-serif",12,"#000000","#000000","#A8B29A","#FFFFFF","left","middle",3,0,500,-5,7,true,true,true,0,true,true);
mm_menu_0803170631_0.addMenuItem("Stel uw vraag","location='contact_form.php'");
mm_menu_0803170631_0.addMenuItem("Lid worden","location='lid_worden.htm'");
mm_menu_0803170631_0.hideOnMouseOut=true;
mm_menu_0803170631_0.bgColor='#FFFFFF';
mm_menu_0803170631_0.menuBorder=1;
mm_menu_0803170631_0.menuLiteBgColor='#FFFFFF';
mm_menu_0803170631_0.menuBorderBgColor='#000000';
mm_menu_0803170631_0.writeMenus();
} // mmLoadMenus()
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<script language="JavaScript" type="text/javascript" src="mm_menu.js"></script>
And another one called mm_menu.js but that file is really big!
If you need it for my problem, just ask =)
