"First of all let's us create a a new layer, name that layer "mask", create a rectangle with any other color then white,"
But the Width i didnot take 117..I took 147 as my Dynamic textfield wid the instance name "display_txt" has a width of 142
"right on top of the "title_txt" textfield, that should fit right beneath the controls." I did this too(the title_txt is my display_txt!!!)
Then i put my display_txt textfield in a new layer called title field (this layer was below the layer "mask")
I then moved my textfield to the right of my mask...my mask(the rectangle) X positon was 4..so wen i moved mt display_txt textfeild to the right i moved it frm X=4 to X=154
I then right clicked on the mask layer and choose MASK...(check the picture for how the masked layer i got looked)
I went on to create a new movie clip and i named it Scroller as told..on the first frame of the newly created movieclip i pressed F9 and wrote these codes
this.onEnterFrame = function() { _root.title_txt._x -= 1; if (_root.title_txt._x < (-100-_root.title_txt.width)) { _root.title_txt._x = 219; } }
NOTE :- I Changed all the title_txt to display_txt
after i did all this and pressed Ctrl+Enter there was no scrolling text plus the song name was also not seen at all...
PLZ TELL ME WHERE I WENT WRONG!!!
