help about web
4 replies to this topic
#1 mhtahir
  • 7 posts
Posted 10 June 2006 - 12:11 PM
how to put ad on page
what is the coding
#2 Matthew.
    Official Spammer .Matt
  • 2,749 posts
Posted 10 June 2006 - 12:22 PM
Can you be a bit clearer please?
#3 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 10 June 2006 - 12:40 PM
what is the coding
Ad Companies give you the required code to place inside your html, and if that's not the answer your wanting then be more specific in your questions.
#4 Danny
  • 262 posts
  • Interests:web design
Posted 13 June 2006 - 08:35 AM
If you want to have adverts on your site there are hundreds if not thousands of ad companys wanting you to join. Your earn penny's by using companys like this, if you want to make your own advert rotating script, they can easily be drawn up in javascript, html and even php.
I currently use my own php roation script using a simple <php include?> code, which means my design isnt altered in anyway, and its only loading the image its shown rather than all of them, which makes my page load faster.
I also earn 100% of the income from the adverts since its my script :mellow: Which is always a plus side. :D
#5 kushaaal
  • 66 posts
  • Interests:Graphology
Posted 13 July 2006 - 10:23 AM
what is the coding
Little vague at this point, however you can try some websites providing you with codes like google adsence, clicksor. You just need to copy the codes and paste whereever you like it to appear.
