making a high poly into a low poly? (3ds max)
Started by
finny06
, Jun 10 2006 02:57 PM
9 replies to this topic
Posted 10 June 2006 - 02:57 PM
Hey , im new to the forum as you can see from my post count ^.^
Ok , when im working with max even though i have 1gb of ram which i consider quite good.. if i do a mesh smooth on something it will slow 3ds max alot!
i only know how to add more polygons (mesh smooth) , does anyone know how to make it into a low poly so i can keep max running smoothly . thanks
- GladysMt likes this
Posted 13 June 2006 - 06:57 PM
Dont know if this help, but when you apply mesh smooth, you can tell max to update the settings in the renderer(in the right parameter window). It is set to update always by default. By this way the viewports wont update the modifier and you can work on the modell and still render it in a smoothed version.
DC
DC
Posted 14 June 2006 - 12:47 PM
I think the function is called "LOD" (level of detail), but i am not sure since i dont really work often with 3DSMax.
Posted 15 June 2006 - 08:39 PM
Simply select the edges one by one which you think are waste and click remove in the editable mesh or poly properties in the modify panel of the control panels. Do this until you have the desired number of polygons.
Edited by mihir, 15 June 2006 - 08:41 PM.
Posted 16 June 2006 - 12:21 PM
LOL, k
Supose hes got 120 000 polygones and he wants an actual count of 10 000 --> you may do it.
Still its a way that always works on the other hand.
#6
Posted 16 June 2006 - 11:00 PM
Another thing to remember is that when you model something in Max, you have to model it in low - poly and apply mash smooth or turn on use subdivision surfaces for polygons.
#7
Posted 17 June 2006 - 03:27 PM
Looked it up: sry LOD plug-in is nothing for you:
it just draw the background in less detail, so it can renew more quickly, like in-game...
#8
Posted 23 July 2006 - 10:41 AM
In the meshSmooth roolout change the Iterations to 0, its under the Subdivision amount. This will keep the image low poly but make it nice and smooth witout adding the poly count to it.
-Devyn
-Devyn
#9
Posted 26 July 2006 - 06:36 AM
In the meshsmooth rollout theres a thing called render iterations. Check the box next to it then its exactly the same as the other one except it'll only show in the render. Then the other 1 will be 4 in the view port
#10
Posted 26 July 2006 - 09:57 AM
there is a modifier in 3ds max call 'optimize' ... you can reduce the poly count with that.
