Globe Motion Tween Help!
3 replies to this topic
#1 newflasher
  • 2 posts
Posted 22 June 2006 - 12:08 PM
Hi all,
Need some help animating my globe...
I created an animated globe animation using motion tween...it works fine EXCEPT the when I choose Motion Tween > CW or CCW it does not look like a globe should rotate. I want it to rotate left to right and not like a wheel (as it does with CCW or CW).
Any clues on how to make my globe rotota like the earth does and not like a wheel
HELP! :P
#2 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 22 June 2006 - 01:14 PM
Basically you can't!
Flash isn't a 3d software with a Z-Axis.. but... I've seen some experiments made with flash 8 which are solely done with Actionscript.
I'm not even sure if this tut would help you, I think this is more for basic elements drawn in Flash, even then, it's pretty hard to learn since you need a lot of scripting
http://www.kirupa.co...ipt/3dindex.htm
One workaround is create a globe with after effects, there is a tutorial on the twodded section of this site, output it as an flv and embed it into your design.
#3 newflasher
  • 2 posts
Posted 22 June 2006 - 01:22 PM
View Postnewflasher, on Jun 22 2006, 12:07 PM, said:
Hi all,
HELP! :)
Thanks. I'll check out the links and After Effect tutorial. Yeah, I did not think it would be all this complex 3D stuff. I've seen this done on many sites in their Flash intros.
#4 funkysoul
    The Funky Stuff
  • 2,307 posts
Posted 22 June 2006 - 01:46 PM
Most of them, were made with Swift3D / swish /After Effects
have a try and post on http://www.13dots.com they are good guys when it comes to swish stuff
