Need help! ....please help me
  • Please log in to reply
1 reply to this topic
#1 rehmankhan
rehmankhan
  • 1 posts
Posted 04 July 2006 - 09:14 AM
Description of Program
Use the files from Assignment #2, rewrite spaceship.cpp (I have posted this file below) to write a space ship Fighting game.
Two Player Game –
Ask each player for his or her name, and then give him starting values for his stats (up to you). Now take turns asking the players whether they want to attack or fix damage on their ship. If they attack, use the roller to decide if they hit and then use their laser power and the other player’s hull strength to decide what values they need to roll in order to hit, then use laser power to decide on damage. If the other player’s damage points goes over his max damage points, then he is dead and loses the battle. Award Laser or Hull upgrades to the winner. Give them the option of playing again.
Example of calculating a hit for player 1
Roller oneToTwenty(1, 20);
Roller damageRoller(1, 1 + player1.GetLaserPower() );
int dmgAmt;
int roll = oneToTwenty.GetRoll();
if( player_2.I****(roll) )
dmgAmt = damageRoller.GetRoll();
player_2.GiveDamage(dmgAmt);
// Check if player 2 is dead , if so, inform him/her of the
// victory , otherwise continue to player 2’s turn
One Player Game –
Create several different opponent spaceships of increasing strength (at least 6) . Make the player fight them one after the other in a similar fashion to the two player game, awarding upgrades upon each victory.
You may make your game different than specified here, ONLY with instructor approval.
Here is an example of code output
Choose ..
0 - Exit
1 - One Player Game
2 - Two Player Game
1
What is your name pilot? Chris
Ok, lets take off captain Chris
You have encountered a Nebulan Fleet
What do you wish to do?
1 - attack
2 - fix damage
3 - check stats
1
You rolled a 9 on your attack
You missed
The Nebulan Fleet attacks you with its lasers
The enemy has missed
1 - attack
2 - fix damage
3 - check stats
1
You rolled a 18 on your attack
You hit the enemy giving 1 damage
The enemy has hit you! Causing 2 damage
1 - attack
2 - fix damage
3 - check stats
2
You fix 3 damage to your ship
1 - attack
2 - fix damage
3 - check stats
1
You rolled a 13 on your attack
The enemy has hit you! Causing 1 damage
some time later . . .
1
You hit the enemy giving 2 damage
You have defeated the enemy Space Raptor
Congratulations
You receive
a Laser Upgrade
You have encountered a Stealth Interceptor
1 - attack
2 - fix damage
3 - check stats
3
Your Stats are
Name = Chris
Damage = 4 out of 10
Hull Strength = 2
Laser Power = 3
1 - attack
2 - fix damage
3 - check stats
I am posting my spaceship.cpp, which is working fine. This home work question is just an extension to my files. So, if anybody knows how to get this output, please let me know. My home work is due July 13th. I have posted my codes below here in reply.
//File: Spaceship.h
# include <string>
using std::string;
class Spaceship
public:
	// A default constructor, it takes no parameters and
	//sets the data member variables to some default values.
	Spaceship();
	Spaceship(string, int, int, int, int);
	// Get - Set accessor methods for data members
	void setPilotName(string); // Data member for piolt's name
	string getPilotName();
	void setMaxDamagePoints(int); // Data member for Max Damage Points
	int getMaxDamagePoints();
	void setCurrentDamagePoints(int); // Data member for Current Damage Points
	int getCurrentDamagePoints();
	void setHullStrength(int); // Data member for Hull Strength
	int getHullStrength();
	void setLaserPower(int); // Data member for Laser Power
	int getLaserPower();
	bool IsDead();
	// This member function Returns true if damage points
	//is greater than or equal to max damage points
	void FixDamage(int);
	// This member function Subtracts amt from Damage Points
	void UpgradeHull();
	// This member function Upgrade Hull Strength
	void UpgradeLasers();
	// This member function Upgrades Laser Power
	void GiveDamage(int);
	// This member function should add amount of damage points to DP
	bool I****(int);
	// This member function returns true if
	// roll is higher than 10 + Hull Strength
	void PrintStats();
	// This member function prints pilot name, damage points,
	//max damage points, laser power and hull strength
private: //Private member functions
	// Declaration of variables
	string pilotname; // Variable for pilot name is declared as a string
	int maxdamagepoints; // Variable for maximum damange points is declared as an integer
	int currentdamagepoints; // Variable for current damage points declared as an integer
	int hullstrength; // Variable for hull strength is declared as an integer
	int laserpower; // Variable for laser power is declared as an integer
//File: Spaceship.cpp
#include <string>
#include <iostream>
using std::string;
using std::endl;
using std::cout;
#include "Spaceship.h"
Spaceship::Spaceship(string name, int maxdamage, int currentdamage, int strength, int power)
	pilotname = name;
	maxdamagepoints = maxdamage;
	currentdamagepoints = currentdamage;
	hullstrength = strength;
	laserpower = power;
void Spaceship::setPilotName(string name)
		pilotname = name;
string Spaceship::getPilotName()
		return pilotname;
void Spaceship::setMaxDamagePoints(int maxdamage)
int Spaceship::getMaxDamagePoints()
		return maxdamagepoints;
void Spaceship::setCurrentDamagePoints(int currentdamage)
int Spaceship::getCurrentDamagePoints()
		return currentdamagepoints;
void Spaceship::setHullStrength(int strength)
int Spaceship::getHullStrength()
		return hullstrength;
void Spaceship::setLaserPower(int power)
		laserpower = power;
int Spaceship::getLaserPower()
		return laserpower;
bool Spaceship::IsDead()
		if ( currentdamagepoints >= maxdamagepoints)
		// if current damage points are greater or qual to
		// maximum damage points, return true
			return true;
		else
		// else return false
			return false;
void Spaceship::FixDamage(int amt)
		if (amt >= currentdamagepoints)
		// If amt is greater or equal to current damage points,
		// currentdamagepoints is qual to currentdamagepoints - amt
		currentdamagepoints = currentdamagepoints - amt;
void Spaceship::UpgradeHull()
		hullstrength = hullstrength + 1;
		//Adds one to hull strength and sets it as
		// a new value of hull strength
void Spaceship::UpgradeLasers()
		laserpower = laserpower + 1;
		//Adds one to laser power strength and sets it as
		// a new value of laser power
void Spaceship::GiveDamage(int amount)
		currentdamagepoints = currentdamagepoints + amount;
		//Adds current damage points and amount and makes it
		//new value for current damage points
bool Spaceship::I****(int roll)
		if ( roll > (10 + hullstrength) )
			return true;
		else
			return false;
void Spaceship::PrintStats()
		cout << endl;
		cout << "YOUR STATISTICS" << endl;
		cout << endl;
		cout << "Your Name: " << pilotname << endl;
		cout << "The Current Damage is " << currentdamagepoints << " out of possible damage of " << maxdamagepoints << endl;
		cout << "The Hull Strenght: " << hullstrength << endl;
		cout << "The Laser Power: " << laserpower << endl;
//File: Spaceshiptest.cpp
#include <iostream>
#include <ctime>
#include <string>
#include "Roller.h"
using std::endl;
using std::cout;
using std::cin;
int main()
	srand(static_cast<unsigned int>(time(NULL)));
	Roller OneTen(1, 10);
	//Sets the random number generator to generate number
	// between 1 to 10
	Roller roll(1,30);
	Roller fix(1,5);
	cout << "RANDOM NUMBERS" << endl;
	cout << endl;
	for(int n = 0; n < 10; n++)
	//For loop for  n to go 0 to 9
	//Loop will run 10 times
	cout << OneTen.GetRoll() << endl;
	cout << endl;
	Spaceship Boat("", 10, 0, 1, 1);
	//Delcaration of variables
	string pilotsname;
	cout << "Enter your Name Pilot: ";
	cin >> pilotsname;
	// Asks user to enter name
	Boat.setPilotName(pilotsname);
	//Sets the entered name
	cout << "Ok, Lets take off Captain " << Boat.getPilotName() << endl;
	cout << endl;
	Boat.setMaxDamagePoints(10);
	//Set maximum damage points to 10
	Boat.setCurrentDamagePoints(0);
	//Set current damage points to 0
	Boat.setHullStrength(1);
	//Set the hull strength to 1
	Boat.setLaserPower(1);
	//Set the laser power to 1
	Boat.PrintStats();
	//Print the statistics
	Boat.UpgradeHull();
	//Upgrade hull stregth
	Boat.UpgradeLasers();
	//Upgrade laser power
	Boat.GiveDamage(Boat.I****(roll.GetRoll()));
	Boat.PrintStats();
	//Set maximum damate points to 10
	Boat.setCurrentDamagePoints(13);
	//Set current damage point to 11
	Boat.PrintStats();
	if (Boat.IsDead()== 1)
	cout << endl;
	cout << "GAME OVER" << endl;
	cout << endl;
	return 0;
//File: Roller.h
#pragma once /* this tells the compiler that this
				file may only be included once to
				prevent linker errors */
class Roller //Class Roller
public:		//publically accessible member functions
	/* unsigned int is an integer that cannot
	 * be negative */
	Roller(unsigned int, unsigned int);
	/* GetRoll returns a number from
	 * (and including) m_Min to m_Max */
	unsigned int GetRoll(void); /* void here is the same
								   as no parameters */
	unsigned int m_Min;
	unsigned int m_Max;
//File: Roller.cpp
#include "Roller.h"
#include <iostream>
using std::cerr;
using std::endl;
// This is a constructor to set the values of the memeber variables using the parameters
Roller::Roller(unsigned int min, unsigned int max)
	// Check to make sure m_Min < m_Max
	if(min > max)
		/* cerr is a separate stream
		 * similar to cout, but for errors
		 * only */
		cerr << "min can't be greater than max"
			 << endl;
		exit(1); // end the program
	//Definig variables
	m_Min = min;
	m_Max = max;
unsigned int Roller::GetRoll(void)
	return m_Min + rand() % (m_Max - m_Min + 1);
#2 Mr. Matt
Mr. Matt
    Moderator
  • Validating
  • 1,945 posts
  • Gender:Not Telling
Posted 05 July 2006 - 11:43 AM
my suggestion, go talk to your teacher and ask for help
why? because you won't learn anything by us telling you what to do, you will look at it, go 'OK' then forget it. If you go to your teacher they can explain it through and you will understand better ;)
Matt
