This may be really easy to fix, but ive followed every tutorial on this site for fading text, and the fade works when i scroll through the movie in the development area, but when i export or preview, it does nothing. Am I missing something..?
Alpha problem..
Started by Doonce, Jul 16 2006 06:37 PM
7 replies to this topic
Posted 16 July 2006 - 06:37 PM
Posted 17 July 2006 - 03:14 PM
Crash Course on Fading text in and out:
1. go to frame 1 of the timeline, write your desired text using a static text box
2. select the text and press F8, convert it into a graphic
3. go to frame 30 of the timeline and press F6 to create a keyframe
4. go to frame 1, select the text, go to the properties panel and select alpha from the dropdown, set it to 0
5. go to frame 10, again create a keyframe (F6) go to the properties panel and select alpha from the dropdown, set it to 100
6. Do the same on frame 20, alpha 100
7. on frame 30, select the text again and choose Alpha 0
8. select the first 3 keyframes, right-click and choose motion tween
you're done...
GL
Funkysoul
you're done...
GL
Funkysoul
Posted 17 July 2006 - 06:18 PM
did exactly what you said, didnt work.
I can get it to work on everything, but not text. I am using Flash 8 Pro.
flash file
flash file
Edited by Doonce, 17 July 2006 - 06:27 PM.
Posted 17 July 2006 - 06:24 PM
ok, 10seconds job.. have a try
PS: rename the file to .fla
Posted 17 July 2006 - 10:03 PM
so what was wrong with mine, because i dont see any difference between yours and mine... Other than yours works and mine doesnt.
Edited by Doonce, 17 July 2006 - 10:03 PM.
#6
Posted 18 July 2006 - 06:26 AM
post your fla so I can have a look at it.
#7
Posted 18 July 2006 - 05:26 PM
I did, its a link called Flash File like 4 posts up.
#8
Posted 18 July 2006 - 05:36 PM
ok error found
Have you read Step 1 of my short tut?
You used a dynamic text box, no fear it also works with that one, but you need to embed the font, and then it will work.
