Need help w/Lasso Tool
4 replies to this topic
#1 nlb
  • 5 posts
Posted 21 July 2006 - 12:05 PM
Okay i have a quick ?'s-------> i used the Lasso Tool to highlite One person rite------> and then after that i'm trying to put them into a plain Background color! and add aonther person on next to that person!
but i got lost on what to do next after i have selected just the person itself! i don't know how to cut them out and but it onto the new background image.
and how do i make the person to be so that the edges of the person i selected will be smooth edges instead of sloppy one of course..because the lasson tool isn't necessary croping the person that great!
Can someone tell me this? please!
<_<
#2 Varelse
  • 65 posts
Posted 21 July 2006 - 03:39 PM
You can use Extract filter - you have to highlight person's silhouette and then fill the outline - you'll get the person extracted from the background with smooth edges (in fact to achieve good results you'll have to get some experience with it - for example different outline width will give you different edge accuracy).
#3 wilson44512
  • 18 posts
Posted 27 July 2006 - 03:06 PM
extract
#4 Scythar
    Honored X Staff
  • 1,888 posts
Posted 28 July 2006 - 12:49 PM
or, with selection active, just choose the "move tool" (the blak arrow in toolbox) and drag it.
#5 sq3r
  • 239 posts
  • Interests:I like stuff.
Posted 01 August 2006 - 11:42 PM
Another good method is to use paths to select the people, and then a layer mask to separate them from the background. If you have any questions go ahead and PM me and I'll help out.
