hey, i need sum help and it requires moving animated text. the theory is i want say my name, parks. i want the p to show first, then the a, then the r, k,then finaly the s. so my name is appearing a letter at a time. then on another project, i want the p to show first, then to dissapear. then the a to show, then to dissapear and so on. once the s has showd, and dissapeared, the word 'parks' then appears as a whole.. any help would be appreciated. thanx
pleeeeeez help me wiv animated text
Started by parks, Jul 24 2006 05:15 PM
3 replies to this topic
Posted 24 July 2006 - 05:15 PM
Posted 25 July 2006 - 05:36 AM
Using Photoshop & Imageready?
If so, I wrote a tutorial a while ago http://www.13dots.co...showtopic=14217
You can also search for 'Animated text' here in Pixel2life.
Edited by PSgirl, 25 July 2006 - 05:37 AM.
Posted 25 July 2006 - 07:30 AM
yeah thats wot i mean cheers for that psgirl.. but wot about a tutorial on where each letter appears then dissapears. ie, p appears, then dissapears, a appears, then dissapears, r appears then dissapears, k appears then dissapears, and s appears then dissapears, then the whole word parks appears.
Posted 25 July 2006 - 10:32 AM
You can use the first tutorial I gave you. Just add a white frame (hidding all the layers) after the layer where the letter appear. Then repeat for each letter.
In my tut:
Then, in the next frame, hide the '1' layer, setting its layer to invisible (clic over the eye to make a layer invisible).
Repeat for each letter.
And finally, after the last letter (s in your case), create a new frame and set all letters to visible.
If you read the tutorial, you'll get how animation works and then you'll be able to customize it.
In my tut:
myself said:
2. With the first frame selected, set '3','d','o','t','s' layers as invisible (clic over the eye to make a layer invisible). So we have only the '1' layer as visible.
myself said:
3. Now, with the third frame selected, make '1' and '3' layers visible.
