Avatar tutorials help
9 replies to this topic
#1 SNation
  • 5 posts
Posted 27 July 2006 - 09:02 AM
iv looked every were for a tutorial to help me do this..(pic has been added)..how do u make the txt shine like in the pic added?
#2 PixelWarrior
  • 8 posts
Posted 27 July 2006 - 09:44 AM
First of all make 3 layers. And change the frame rate to 30fps
Rename them: Mask, Shine, and Text in that exact order from top to bottom.
1. Select your 'text' layer and type in your text eg. Zeylin with the text tool and play around with it until you're satisfied.
2. Copy this, select the 'mask' layer and then press Ctrl + Shift + V to copy it in exactly were it was. Now right click this text in your 'mask' layer and select Break Apart. This should break your text into individual letters. Repeat and it will now be a set of shapes. //Masks only work with shapes.
3. Right click on your 'mask' layer and select Mask. Now that you have selected Mask, the 'shine' layer you name earlier will become indented.
4. Select the Rectangle Tool, click and drag a suitable sized box (in your shine layer). Make the fill white, or whatever you want. Maybe play around with its alpha or gradient. Rotate the rectangle to the desired angle and place it infront of the text
5. Create a key frame at frame 50 and paste the rectangle in frame 50 on the same layer. Select the rectangle and place it behind the text.
6. Select frame one of the 'shine' layer and on the properties menu down the bottom select Motion Tween.
7. Press Ctrl + Enter to test...
Edited by PixelWarrior, 29 July 2006 - 06:40 PM.
#3 SNation
  • 5 posts
Posted 27 July 2006 - 10:06 AM
i donno what i did but i cant get it to work.....
Edited by SNation, 27 July 2006 - 10:17 AM.
#4 PixelWarrior
  • 8 posts
Posted 27 July 2006 - 10:14 AM
right click on frame 50 and select key frame for each of the 3 layers
#5 SNation
  • 5 posts
Posted 27 July 2006 - 10:21 AM
ahh i got that but its not working.. i made the 3 layers txt, mask, and shine click txt n typed in SNation..now i copyed the txt click mask break apart 2x right click mask select mask... took the rectangle tool...is the rectangle sapose to go on top or under the txt....i think from diss part on i screwed up
#6 SNation
  • 5 posts
Posted 27 July 2006 - 10:31 AM
ahh i think im close diss is what i did n got but i cant get the hine to work now
ill b bac in 1hour from now ... time 11:30am
#7 PixelWarrior
  • 8 posts
Posted 27 July 2006 - 10:36 AM
sorry i made a mistake, make the mask layer above the text. Click here for .fla
#8 SNation
  • 5 posts
Posted 27 July 2006 - 01:31 PM
errrr i still cant get it...4 years since iv worked with diss stuff n html n all dat stuff...
#9 PixelWarrior
  • 8 posts
Posted 29 July 2006 - 06:32 PM
Try and go through the steps again now, I've edited out a few minor errors.
#10 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 29 July 2006 - 07:22 PM
have this one ^_^
http://www.kirupa.co...hine_effect.htm
