Hello everbody,
Just found this website and I was hoping someone could help me.
I have lost my painting abilites in Photo-Paint. When I click on the paint tool, everything seems OK; I can select the brush type, size, etc, but when I drag the brush, nothing shows up. I've played with the transparency, and it doesn't seem to help. I'm sure it's just something simple like a setting somewhere, but it's driving me crazy!!
Any help is appreciated
Thanks!
Corel Photo-Paint 12 Problem
Started by Fitch, Aug 10 2006 09:54 AM
2 replies to this topic
Posted 10 August 2006 - 09:54 AM
Posted 10 August 2006 - 10:22 AM
Are you trying to paint on a layer that is locked? There's a button at the bottom of your Objects docker called "Lock Object Transparency". See if that is pressed inward.
Posted 10 August 2006 - 11:10 AM
Thanks for the reply Jacorre but, no the layers are not locked. I'm just a beginner with Corel, but I' ve always been able to airbrush over objects when I wanted to. But I can't airbrush, pencil, marker, or anything. It's just like I'm painting clear. It's driving me crazy. I'm almost to the point of reinstalling the software.
Thanks again.
Edited by Fitch, 10 August 2006 - 11:11 AM.
