Hi guys,
I am pretty new to photoshop - I'm currently using CS 8.0. I recently was asked by a company to design an image for their "under maintenance page". I did this and sent off a few examples to the guy. He replied, can you please send them in html format. I figured out that I could slice the image up into smaller files using the slice tool and then save as "html with images". I sent these off and his reply was, "These aren't actually HTML pages, just a big graphic cut up into parts. I'd like you to create a real HTML page for each design."
I'm pretty confused now with what I'm supposed to do, but don't want to ask as I'll look like a dummy and that I'm not up for the job. Can someone please point me in the right direction? It's a very basic page - that simply contains an image saying the site is under maintenance.
Any help would be greatly appreciated.
Kind regards, Digger
HTML/Photoshop help
Started by digger123, Aug 16 2006 04:28 PM
2 replies to this topic
Posted 16 August 2006 - 04:28 PM
Posted 16 August 2006 - 05:53 PM
You want to slice out say the main logo or whatever it is and code it by hand.
Example:
Instead of using images & tables which is what CS produces, use a single image and a background color (replace [color] with the hex) and also add positioning etc.
Example:
<html>
<head>
<title>Untitled</title>
<style type="text/css">
body { background: [color]; }
img { border: 0; }
</style>
</head>
<body>
<img src="image.ext" alt="image alt" />
</body>
</html>
Edited by .Matt, 16 August 2006 - 05:54 PM.
Posted 17 August 2006 - 02:19 AM
choose "jump into imageready" and there you can save (or was it optimized) as... it will be the html and all the bits and pieces you are referring too.
