Popup help
6 replies to this topic
#1 Indigo
    Official Alien
  • 617 posts
  • Interests:Computing in general, especially design and programming of all kinds.
Posted 22 August 2006 - 06:22 AM
My script finds all files in a folder and link to them. What I want is a checkbox at my site. If the checkbox is checked, open any links clicked in a new window with the size 300x400.
If you need the script, I'll gladly post it :rolleyes:
#2 Demonslay
  • 970 posts
Posted 22 August 2006 - 03:19 PM
Tad tricky, can JavaScript be used as a form action?
If so, you could add all the chackboxes as inputs (echoed with your PHP of course) that would look something like this.
<input type="checkbox" name="selected[]" value="<?php echo $filename; ?>" />
Then, in your processing form, you could make it send to a .js page with nothing but a loop that will use the window.open command with the filename and such. :biggrin:
Though, if that can't be done, then maybe using something like a button with the OnClick event handler, and have a function that will grab all the values of selected[] and pop them open.
#3 Indigo
    Official Alien
  • 617 posts
Posted 23 August 2006 - 02:39 PM
My problem is the window.open(), because the filename isnīt allways the same, it depends on what files that is in my folder. I need a script to fetch the filename, and then open that file in a new window.
Could it be done as simple as this:
<a href="#" onClick="window.open(set heigth and witdth etc here)">my random link gotten from folder</a>
#4 Demonslay
  • 970 posts
Posted 23 August 2006 - 03:59 PM
You completely missed what I just posted apparently...
I am aware of your dynamic images in the directory.
And you said originally you would like to open them all with one click via checkboxes and a submit button, correct?
I finally found my old window.open() syntax (I'm horrid at JavaScript, can't remember a dam thing).
Here's a small draft of an overall script, more or less.
if(!$_POST){ // If no post data (nothing has been submitted)
/* Your functions/code to retrieve all the files in a database, storing them into an array I hope */
<form method="POST" action="<?php echo $PHP_SELF; ?>">
foreach($files as $file){ // Loop through and echo each file in the array
<br /><input type="checkbox" name="selected[]" value="<?php echo $file; ?>" /> <strong><?php echo $file; ?></strong>
<input type="submit" value="Open Images" />
</form>
else{ // Else if there IS post data
echo '<script language="Javascript" type="text/javascript">';
foreach($_POST['selected'] as $file){
echo 'window.open('.$file.', _blank, \'width=300,height=400\');';
echo '</script>';
Arg, I was going to do it mostly in JavaScript instead of using PHP to echo the JavaScript, but the are no real foreach loops in JavaScript, and the one I found that someone made was over my head...
Tad cruel in my opinion, but in theory would work.
Someone else who actually knows JavaScript could probably clean this up, since I can't find a good way to use something like a foreach loop in JavaScript. ;)
Edited by Demonslay, 23 August 2006 - 04:01 PM.
#5 Matthew.
    Official Spammer .Matt
  • 2,749 posts
Posted 23 August 2006 - 04:29 PM
lol,sorry to burst your bubble demonslay...
function targetChange()
	var anchors = document.getElementsByTagName("a");
	if(document.getElementById('check').checked == 1)
		for(var i = 0; i < anchors.length; i++)
			anchors[i].target = '_blank';
	else
			anchors[i].target = '_self';
<input type="checkbox" id="check" value="tumadreesuncochemuyviejo" onclick="targetChange()" />
<a href="http://google.com">test</a><br />
<a href="http://google.com">test2</a>
I am in no way a javascript 'expert' though so i would hope that works ;) (seems to with me), however it does not open the window in a certain size...why? because for some reason everytime i added that part the original window would show the action....i dunno, as i said im not great at JS.
Its something to work on i hope.
Matt.
As you can see demonslay, i have used a simple loop against the length of the array (in this case the amount of hyper links in the page) as a foreach.
Edited by .Matt, 23 August 2006 - 04:34 PM.
#6 Demonslay
  • 970 posts
Posted 23 August 2006 - 05:18 PM
I never knew how to get the length of the anchor's array. The only JavaScript I am somewhat good at is a few event handlers and that's about it. :P
That's odd, I think his first post changed. I swear he said he wanted to open a ton of images in one click. ;)
Or is that another thread...
#7 Indigo
    Official Alien
  • 617 posts
Posted 24 August 2006 - 01:03 AM
Thatīs another thread.
Donīt know if I really got this right (Iīm a bit slow :unsure: ) but Iīll try it out. Thanks anyway ^_^
