3dsm custom bitmap help
4 replies to this topic
#1 DarkRaven
  • 3 posts
Posted 05 September 2006 - 12:12 PM
Hi, I've got a problem in 3D Studio Max 8. I've been trying several times to add my own custom made textures or textures I've downloaded (Bitmaps), but after selecting the bitmap I'm not able to add it to an object.
I'm creating a building and I need to add a plank texture. After finding some textures that I might wanna use I add them as a bitmap material. The problem is that the "Assign material to selection" button isn't clickable.
-Screenshot-
-A render of my model-
Thanks for any kind of help :D
#2 Stu
  • Publishing Betazoids
  • 1,761 posts
Posted 06 September 2006 - 04:08 AM
why dont you want to just assign the map to the diffuse slot of a standard material like you have for the other materials in your scene?
#3 DarkRaven
  • 3 posts
Posted 06 September 2006 - 04:18 AM
Hmm.. great.. thanks :)
#4 Stu
  • 1,761 posts
Posted 06 September 2006 - 04:30 AM
View PostDarkRaven, on Sep 6 2006, 10:18 AM, said:
Hmm.. great.. thanks :D
it wasnt a rhetorical question :) i was just wondering why, incase i was missing something and you needed it to be like that :D
#5 DarkRaven
  • 3 posts
Posted 07 September 2006 - 11:43 AM
Anyway :love: It worked and I'm done so you did help me :mellow:
