Business Card (wip)
4 replies to this topic
#1 blackhawk_996
  • 59 posts
Posted 18 September 2006 - 02:28 AM
Just wondered if I could get some comments on my work in progress.
Having been asked for one for the fourth time I thought it best to try and make myself up a card. They will be printed individually at home so I'm not to worried about cost. I am just after something some what unique. Thanks for your feedback and suggestions. I used a thumb because the original is rather large (I kept it at 300dpi).
Edited by blackhawk_996, 18 September 2006 - 02:29 AM.
#2 Davey
  • 620 posts
  • Interests:Creativity, Adrenaline, Etc
Posted 18 September 2006 - 02:42 AM
bit big to fit in my pocket ... joke
it looks pretty good, tho i would lower the opacity of the glow by about 10%
#3 goaliemike
  • 89 posts
Posted 18 September 2006 - 07:44 AM
IMO the glow is fine, because depending what type of printer and paper your using it might not be as visible :D
Very nice, the whole thing works well together, id print one to see what it looks like so then you can tweak it from there.
#4 Dh.
    CSS Guru
  • 807 posts
Posted 18 September 2006 - 08:06 AM
That pretty nice, good job - i think it looks fine.
#5 Kai Fluegel
  • 32 posts
Posted 19 September 2006 - 11:56 AM
I'm not sure about this, if this card had no text on it then I would assume that it would be a flower shop, not a web design shop. It would be nice if you made a little logo, or even mess with your text a litte and make that into your logo.
Edited by Kai Fluegel, 19 September 2006 - 11:56 AM.
