3Ds Max, Vertice/Filling problem
3 replies to this topic
#1 lostseed
  • 225 posts
  • Interests:Illustrator, Photoshop, PHP, CSS, XHTML
Posted 18 September 2006 - 10:07 AM
See the pic?
I want to make a line connecting the two points, then I want to fill in the hollow part.
I cant figure out what in the world to do!
I tried Attach and Slice and all that, Collapse too I been using but not for this.
Plz tell me :D
#2 caboose
  • 62 posts
Posted 18 September 2006 - 11:58 AM
ok i dont totaly understand what you want to do
but if i understand what you want to do just do this
convert it to "poly"
under "edit geometry" select "create"
then just click the 3 "dots" as shown below
then just do the same for the rest pf the empty parts
hope this helps you man :blink:
#3 lostseed
  • 225 posts
Posted 19 September 2006 - 12:23 PM
ya that did help but i couldnt get it working, found out I have to click 3 points then double click the last point.
how frustrating! :blink:
thanks guy
#4 lostseed
  • 225 posts
Posted 20 September 2006 - 04:00 PM
Oh also, to fill that it works best in Polygon mode (not as easy in vertice).
Just incase anyone has the same problem :ph34r:
