Help with template
1 reply to this topic
#1 reveng
  • 1 posts
Posted 22 September 2006 - 03:00 AM
After doing my slicing "correctly", and making sure that my two repeating bars on each side will surely stretch out, I need some help. My main table right in the middle is giving me one big of a headache. I know how HTML works, but I'm not an expert at it. Firstly when I want to create a new table over it on the top, it either ends up below it or it screws the top of my template. I try making the main content table "image" a background instead but then my template from the left to right collides together. I looked around for tuts that show me a similiar technique I try pulling off but nothing's working for me right now. Is there any suggestions to my problem?
#2 RobCullen
  • 25 posts
Posted 22 September 2006 - 06:47 AM
haha so many times ive had this problem with my slices its simple to do you see the tag <td col=4 or sommot like that keep that then delete the image tags type background="whatever.gif" leave teh size if you want but dont remove that colspan as its will collapes ur tables.
<td colspan="4" background="whatever.gif"> text area now <td>
should look something like that not sure of the exact code just delete the image tags and inset the image as a background like that above.
hope this helps if not then im sure if i follow you hehe :D
