Remote Desktop Connection
16 replies to this topic
#1 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 06:22 PM
I need help Setting up my remote desktop connection...
I have followed these here...
The First One
The Second One
When I try to connect from a different internet connection i get an error. I need help. Has anyone else here ever done a remote desktop connection before?
#2 l3lueMage
    Wanna Be Moderator
  • Publishing Betazoids
  • 4,596 posts
Posted 24 September 2006 - 06:39 PM
I usually just use MSN Messenger for remote desktop :ph34r:...if the 2 computers have fast internet or are on a LAN remote desktop works just fine through MSN messenger and its easy to setup, all you do is send an invite to the other :P
#3 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 06:53 PM
hmmm, I didnt know msn messenger had that feature. Is it kinda like the thing in aim where you can send files to each other? Because thats not what I want. I actually want a "Remote Desktop" Connection.
#4 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 24 September 2006 - 07:18 PM
you can go right into another computer and use it with windows live messenger
#5 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 07:21 PM
ohhh ok i'll try it out. I already have a hotmail account.
Can I use my internet connection through it. The one i will be connecting to?
#6 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 24 September 2006 - 07:35 PM
the other pc needs to have an internet connection as it needs to give you permission to come in.
#7 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 07:40 PM
ok, this may sound stupid but when i try to login with MSN messenger it says something about a .net passport. What is that?
#8 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 24 September 2006 - 07:42 PM
thats your email address you use to login
#9 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 07:46 PM
oh ok, I typed me email in wrong, thats why it messed up. Im logged in so now what. Where do I go. Does my other computer that im logging into need messenger?
#10 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 24 September 2006 - 07:51 PM
Both computers need to have a connection, both using msn.
On the other pc they need to open a window with you. Actions - Request Remote Help
After permission is granted takes a few mins your inside and have full control of the other PC
#11 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 08:12 PM
ok i looks like I have to upgrade.
Ok I have Upgraded. What about the other computer does it need to be upgraded also?.
<edit>
The new version wont let me log in.?.?.?.?.?.?
Edited by ProjectWhat, 24 September 2006 - 08:14 PM.
#12 Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 24 September 2006 - 09:40 PM
Make a new account for it
#13 ProjectWhat
  • 75 posts
Posted 24 September 2006 - 10:21 PM
I did. I would really like to use xp's remote desktop feature though...
it says this in the troubleshoutting guide to my error:
Quote
<errorBox>The remote connection has timed out. Please try connecting to the remote computer again.</errorBox>
Cause: The terminal server disconnected your session because you did not send a response within the time limit set for responses.
Solution: Try connecting to the terminal server again. If you receive this error message, try to reconnect at a later time. If you continue to receive this error message, contact the server administrator.
Cause: A slow network connection, caused by excessive network traffic, has delayed your response to the terminal server.
#14 Matthew.
    Official Spammer .Matt
  • 2,749 posts
Posted 25 September 2006 - 01:42 PM
Sorry to butt in here but can i suggest instead you use realVNC, http://www.realvnc.com/.
Incredibly simple. Install it on one machine, run the service. Install it on another and run the client. Enter the other computers IP:vncport and your in. Passwords/security options are optional so it couldn't be easier.
#15 ProjectWhat
  • 75 posts
Posted 25 September 2006 - 05:32 PM
Well I cant install things at school. I really need the remote desktopn connection. Please dont try to change my mind unless the Remote Desktop Connection through windows wont work.
#16 cheerio
  • 246 posts
Posted 25 September 2006 - 06:10 PM
try logmein.com if your school comps support JAVA
#17 ProjectWhat
  • 75 posts
Posted 25 September 2006 - 08:53 PM
It is prob. Blocked at school we have the TNA filtering service. Man They Are GOOD! The have blocked every proxy server out there, and of course things like these. also if I could get PHP running from my laptop I could use a PHP proxy script I have on my harddrive which then they cannot block. Well thats a whole nother subject though, maybe later.
