Mysql and PHP help
4 replies to this topic
#1 Crofty
  • 32 posts
Posted 27 September 2006 - 04:03 AM
ok well i am trying to make a top selleres list but when the amountsold goes past 10 it reads it as 1
	$r4 = mysql_query("SELECT * FROM `products` order by `amountsold` DESC LIMIT 0,10");
	while($row = mysql_fetch_assoc($r4)){
	echo'
	  <tr>
		<td width="200" align="center"><a href="index.php?view=dvd&id='.$row['dvdid'].'">'.$row['dvdname'].'</a></td>
	  </tr>';
have i missed out something?
#2 Crofty
  • 32 posts
Posted 27 September 2006 - 10:39 AM
well in my database there is a field called amountsold and once this value increases above 10 it dosent read the second digit
#3 Mr. Matt
    Moderator
  • 1,945 posts
  • Gender:Not Telling
Posted 27 September 2006 - 11:20 AM
you missed the $ from the $r so you will get an error.
Matt
#4 Crofty
  • 32 posts
Posted 27 September 2006 - 12:07 PM
the limit seems to be fine it works atm
#5 Crofty
  • 32 posts
Posted 29 September 2006 - 04:09 AM
EDIT: SOLVED DIDNT MAKE AMOUNT SOLD INT
no sorry i mean the limt worked fine in the first place. every time a product is bought it adds 1 to the amountsold field of that product, but when the amount sold gets bigger than 10 it starts to read the first didgit only for example it reads 10 as 1 and 25 as 2, i dont know why its doing this?
Edited by Crofty, 29 September 2006 - 04:10 AM.
