hi i've added the marquee code and evrything to my affiliate box which is 226 wide and 250= height but i want the affiliates to be in teh center and added the center tag to the image too but its keep appearing on the side right on the content box boundary how can i get it to center?
need help with marquee code in html
Started by nld, Sep 29 2006 10:58 PM
4 replies to this topic
Posted 29 September 2006 - 10:58 PM
Posted 29 September 2006 - 11:12 PM
put the affiliates inside a new table in main affiliate content area, then put the <center> </center> tags around the table
Posted 30 September 2006 - 02:11 PM
thanky uo so much, i tried alot of stuff but hadn't thought of that
Posted 30 September 2006 - 02:17 PM
after i did that my content box got way long its supposed to be 125. do u know how i can fix that so it just stays 125?
the scroll direction is up, and it only does that when i put on up otherwise on left and right its normal.
thanks
thanks
Edited by nld, 30 September 2006 - 02:20 PM.
Posted 03 October 2006 - 06:52 AM
make sure that the width element of both tables is 125, could be in nested table making it wider
