Need help with 3dsm
4 replies to this topic
#1 acheron88
  • 2 posts
Posted 30 September 2006 - 12:01 AM
hey, im brand new to the 3dsm world and i started a tutorial to make a sword model. it requires the use of splines to make a part of the handle and im having trouble with the whole spline vertexes, welding, fusing, etc etc :wacko: im very confused.
my problem is when i get to a part in the tut it asks to surface the splines, and when i add a surface modifier it wont work, it will only surface 2 segments, and the rest of the spline disappears :o i tried playing around with fusing and welding making sure the vertexes are connected and whatnot but im a complete noob so i'm sure i'm not doing it right.
any help is appreciated. thank you ;)
also, if anyone has the time, it would be great if someone could take a look at my problem for me, (perhaps fix it for me :unsure: ) here is the .MAX file download
#2 lostseed
  • 225 posts
  • Interests:Illustrator, Photoshop, PHP, CSS, XHTML
Posted 30 September 2006 - 03:01 PM
See the attachment, they look connected to the lines but they arent.
You also have a lot of unwelded vertices.
Edited by lostseed, 30 September 2006 - 03:06 PM.
#3 lostseed
  • 225 posts
Posted 30 September 2006 - 03:14 PM
Look at this file I edited:
You had to use the [Insert button] (On Vertice Options) then click on a space on the line to make a vertice.
Then you drag the loose lines to that and click Weld, or in the case it was Fuse. (my first time using fuse).
Weld depends on the Threshold, the number beside it, Im only a little bit into 3ds so Im no expert.
Also, you can right click a vertice and select the type of vertice you want it to be, I made them smooth just
for no reason really, you can straighten them out if you want.
http://www.jream.com.../img/sword3.max
I had to flip the normals so it appears the right way. (youll be doing that a lot in 3d)
When you are in the Modify Panel, you apply the surface.
But hit the plus next to the Editable Spline, and once you click Vertex for example, the Surface should dissapear and you can edit the vertexes. If it doesn't click the lightbulb next to the Surface thing.
Also in the 3dsmax Tutorials, if you are using version 8, maybe lower even, they have a chess tutorial on a Knight (Chess Piece) and it uses this same method, but they don't use fuse. I dont know what fuse it really for but it worked lol.
Edited by lostseed, 30 September 2006 - 03:19 PM.
#4 caboose
  • 62 posts
Posted 30 September 2006 - 05:55 PM
i gave this tutorial a go and if you arent use to max it will be confusing you should work your way up starting with simple tutorials
p.s i have to say tho after i tried this tutorial gave be great results the sword looooks sweeet ;)
#5 acheron88
  • 2 posts
Posted 03 October 2006 - 07:43 AM
thanks alot lostseed, helped alot. i almost lost hope in that tutorial, but i decided to have another crack at it and i think i can finish it off now. i'll let you know how i go later. for the future i think ill take ur advice caboose and stick to some more newbie tutorials heh. might post the finished thing when im done, if the model looks worthy haha. ok thanks again :D
