Which template engine?
Posted 02 October 2006 - 04:51 AM
Posted 02 October 2006 - 05:48 AM
You'd probably also be best searching P2L tutorials for "Template Engine"
Edited by Hit3k, 02 October 2006 - 05:50 AM.
Posted 02 October 2006 - 12:09 PM
Posted 02 October 2006 - 03:28 PM
Posted 02 October 2006 - 03:32 PM
Cliff, on Aug 4 2006, 02:51 PM, said:
A quote from Cliff. As i haven't used either i won't endorse it but i reckon he's got a fair idea
I use my own purely because making one is part of me learning and i hate having to redesign without one .
#6
Posted 02 October 2006 - 03:43 PM
That's where you learn
#7
Posted 02 October 2006 - 03:51 PM
If you ask nicely i may consider it lol. I wouldn't advise anyone using it though if anyone is about to pm me to see it (as usually happens) it's
#8
Posted 02 October 2006 - 04:35 PM
Honestly, the use of a template class is optional, but really convenient. If you code it right, it won't hurt performance to much, but it takes a bit of tinkering. Other then that, it's not hard to learn how to make one.
#9
Posted 02 October 2006 - 04:45 PM
Just a side note, this tutorial has just come onto the front page...
Quote
http://tutorialcode....tutorial&tut=14
Good timing i call it.
Edited by Matthew., 02 October 2006 - 04:46 PM.
#10
Posted 03 October 2006 - 02:41 AM
#11
Posted 03 October 2006 - 06:23 AM
#12
Posted 03 October 2006 - 09:37 PM
Quote
But if you are making a script that you want to distribute, you have to use some template engine, as it separates UI with Logic.
Edited by designcode, 03 October 2006 - 09:40 PM.
